Copy Automation Between Lanes/Layers
Saintmatthew
Post by Saintmatthew »
So, maybe I'm missing something but the manual is silent and there's nothing when searching. Is there a way for me to copy automation between "lanes or "layers" in the Sequence editor. I have a usb lighting controller that is run by a VST plugin, and recently added new lights that use slightly different addressing. The easiest way to integrate would be to copy the current automation to additional lanes but it seems to past all the lanes at once. If I hide lanes and select layers, even after changing it pastes the data back into the same layer, even after selecting a new one. Ugggg.
MacPro 12core 64GB Ram 4 1TB SSDs motu 828mk3 DP 10.11
mesayre
Re: Copy Automation Between Lanes/Layers
Post by mesayre »
Not sure if you found a solution, but could you use the "Region->Reassign Continuous Data" command?
If you select the "Copy" option at the top, it'll copy any CC data you've selected to another CC you specify. I imagine that'll do the trick, but I'm still on DP8 so YMMV.
Saintmatthew
mesayre wrote:Not sure if you found a solution, but could you use the "Region->Reassign Continuous Data" command?
That was actually one of the first things I tried. Didn't work at all. Very frustrating.
