Continuous Data scaling
Hi there!
Is it possible to scale the range of the continuous data from, for example, 0-127 to 0-100? I mean that these values must be recalculated not limited.
Thanking you in anticipation.
#define QUESTION ((bb) || !(bb))
-= (C) 1601 William Shakespeare =-
Re: Continuous Data scaling
In the Region Menu, there is Change Continuous Data... which offers a scale function. That'll do it.
As I can see we have Add.../Limit.../Change%. So do I have to calculate percent to change range of controller? Of course it's not difficult. But I meant something different. For example, change CC#11 from 0-127 to 45-100.
Compression would be useful here. It's available for velocity, so perhaps MOTU can add it for CC data as well.
You might try the Reshape Tool. Set Reshape Action to Scale.
It's not required to set Reshape Mode to Straight Line but for many jobs this setting is a good starting point.
Select the data. Use your mouse to draw above or below the data to be changed, notice the scale markings that appear on the left once you start drawing. Less than 100% decreases existing values.
Takes a few passes to get how it works but I find it more flexible than Change Continuous Data.
MacBook Pro 9,1 15" 16gb | 10.12.4 | DP 9.13 | xAir | NI | WIVI | Garritan | Izotope | Bidule
I'd suggest that you first scale it by percent. Then offset it by just adding a constant value to the entire selection.
So, we are usually starting with values from 0-127, and you want a range of 45 to 100. The latter is a range of 55 values (the range between 45 & 100). You would start by scaling everything by 55/128 (55 divided by 128) = 43%, then do a second process where you add 45 to all values. I'm pretty sure this is right.
Let me test my meager algebra skills:
Let's say X is the bottom value of your range, and Y is the top value of your range, and Z is the percentage that you scale.
Z = (Y-X)/128
Then add X to all values to bring all the relative values up intact to the new range.
Z = (Y-X)/128
Thanks for suggestion. I've got it. The idea was as from Sonar X "Find/Change".
