i had the opportunity this past weekend to test-drive dp8 for windows, and ran into some head-scratchers (in some cases, head-bangers ), i was hoping someone could point the way.
1. VIRTUAL INSTRUMENTS
i was trying to set up an orchestral score using kontakt 5. i set up separate outs from kontakt for, e.g., violins, violas, cello and bass (so 4 stereo pairs coming out of kontakt). for some reason, i wasn't able to hear any of the outputs except output 1-2, the violins. also, for some reason, only outputs 3-n appear in the bundles window, the first output pair doesn't, even though it was correctly created within kontakt. does this also happen for macintosh? (i.e., is this by design, or is this a bug in the windows version?) so i was trying to figure out how to hear the outputs for the rest of the strings and also send the violins someplace other than the main monitor outputs so i could work with them. first, i tried assigning kontakt's outputs to audio track inputs, but even enabling input monitoring and record mode on the audio tracks gave me no results. i eventually found a sort of a work-around, but it's clumsy. i assigned the outputs of all but the first output pair to aux tracks, but had to create a bus for output 1/2 first, then assign the bus to an aux track, because i couldn't assign what dp apparently designates as a 'global' instrument output directly to an aux track. this seems like an awful lot of dancing around to accomplish something relatively simple, i know i must be making this needlessly complicated. what's the accepted method?
2. IMPORTING VIDEO
i imported a video using the 'set movie' option of the pull-down menu in the 'movie' window. this worked fine, w/the exception that the import window took about 15 seconds to pop up. my problem then was, importing the video using this method, i couldn't figure out how to get the movie's audio. i pressed 'play' right after importing the movie and got nothing but silence; the image displayed correctly in the movie frame, but there was no sound. there was no soundtrack on any audio track in the project, and selecting 'import movie audio' did nothing. the movie track displays correctly in the sequence editor. i verified that the movie's audio output was set to my device's output, and verified that the output was working correctly from within dp by putting an audio file on an audio track whose output was set to the same hardware out as the movie's. i made sure that the volume was turned up on the movie control bar. how do i get the movie's audio?
the user's manual says i can import an avi file's audio into the soundbites window, but i get this error:
i used the 'import audio' option of the pull-down menu available in the soundbites window, selecting *.avi from the file type selection criteria pull-down while selecting the file. i've been able to import this exact same avi file into sonar before and both audio and video import w/no issues, and it also plays in windows media player w/o issue, so it's not a problem w/the file.digital performer has encountered an error.
os error: internal error: parameter error (-50)
i tried again, this time with an mpg movie. i get the following error:
one final issue. i saved and closed my little test project and went to grab some food, and when i came back and re-opened the project, i got an error 'unable to locate movie file' and was asked if i'd like to replace the movie i'd imported. this was strange since the movie file was still in the exact same place i'd left it, and when i answered 'yes' to the pop-up, it navigated immediately to the correct location, where i saw the avi and was able to import it again. i was puzzled by this, so immediately saved the project again, closed it, and reopened it. same results. 'show movie in explorer' goes right to where the movie is. is there something else i'd need to do besides 'set movie' in order to make sure a movie stays put?digital performer has encountered an error.
i guess i have one final question. am i encountering these problems because i'm doing something wrong, or because these are bugs in the program?
thanks
dave
