Hi there,
I'm about to order an Ultralite AVB and decided to throw in a set of Beyer Dynamics BT770 Pro earphones. These are available in three flavors: 32, 80 and 250 Ohms. MOTU spec sheet por the Ultralite AVB mentions 80mW output power for the headphone driver. Theu do not specify a recommended load. Will the amp be adequate to drive the 250 Ohm version of the BT770 or should I rather go for the 80 Ohms version? The cans will be used for tracking in a rather quiet environment, I already own a decent set of open-back headphones for late-night mixing
Thanks in advance for your insight
Dirk
Ultralite AVB headphone impedance
