What's your cleanest compressor plug-in?
philbrown
Post by philbrown »
I've been trying dozens of them. This is for some live-recorded spoken word material and there is a slight bit of what I'll call 'spittiness' in the main (headset) mic. Compressors with any 'character' whatsoever seem to accentuate the spitty quality so I'm pretty much searching for the cleanest/smoothest comp I can get. There's an arguable balance between 'smooth' and 'transparent' but that's what I'm after. Ones I've found that work OK are PSP Mastercomp and OldTimer, Native Instruments Solid Bus Compressor and Waves Linear Multi-Band. There are some others that I've tried that are pretty transparent but the timing and grab didn't quite work with this particular material. I'm not compressing hard, just smoothing out peaks and a slight bit of gentle leveling. Most of the work is volume automation and LOTS of it.
I've tried a lot of different EQ's too, but for general sculpting I'm really digging Waves Linear EQ for this task. Masterworks EQ is good too and the different curves and notching work well. Working with this spoken word stuff is more challenging than might appear– trying to get it the best it can be from whatever you're handed.
TIA,
Phil
billf
Re: What's your cleanest compressor plug-in?
Post by billf »
Phil, Have you tried the Fabfilter Pro MB Compressor?
philbrown
Post by philbrown »
billf wrote:Phil, Have you tried the Fabfilter Pro MB Compressor?
Looks great, downloading now - I just hope I don't like it!
Seriously, I think the right multi-band would be the thing.
I need to look into the depths of my arsenal too.
Always nice when "Hey, I own it already!" happens.
Don't ignore the Dynamic Equalizer built into DP!
https://www.youtube.com/watch?v=imx6GK39vEo
Dynamic Equalizer
Precise control of frequency,
volume and dynamics
Dynamic Equalizer combines multi-band EQ with dynamics processing and volume control. Three parametric bands and two shelving bands each provide both volume control and a full-featured compressor, complete with lookahead that can be set to different values for each frequency band. Use the realtime FFT display and solo each band as you perfect the balance and dynamic response across the frequency spectrum. The result? Clarity, balance, and punch, especially for broad-band audio material, such as a drum set or full mix.
2013 Mac Pro 32GB RAM
EMRR
Post by EMRR »
The dynamic EQ won't mimic what the de-esser does either, I find they have to be used in combination at times.
Doug Williams
Tape Op issue 73
DP 11.31
Studio M1 Max OS12.7.3
MOTU 16A and Monitor 8
billf
Post by billf »
philbrown wrote:Looks great, downloading now - I just hope I don't like it!
I made that mistake with their EQ. :D
philbrown wrote:Seriously, I think the right multi-band would be the thing.
Definitely. Between Waves, PSP, and stock, there should be something that works well.
philbrown
Post by philbrown »
Thanks for the recommendations!
EDIT: I know quite a few people here own Komplete, and if you're like me, when you think of 'Native Instruments' you don't think of high-quality comps and EQ's but their Solid series of processors are really good and worth giving a try. I like them better for some applications than some I've bought separately and paid good money for.
I'm happy with the ones in the various Izotope plugs I own, especially Ozone. The ones in DP work well for me, too.
Phil O
Post by Phil O »
Phil, I'm not sure what you mean by spittiness. Is it the over emphasis of consonants at the beginning of a word? Are your compressors not fast enough to catch those? (I'm just speculating, here.) If by chance you do need something faster, try Rocket from Stillwell. It's got attack times in the microsecond range. It's also got side-chain capability. There's a free demo and I think it costs about $50 for individual license.
There's also a nice compressor in Melda's free bundle. It can be adjusted to be quite transparent. I think the upgrade to paid version was around $50 as well (for the whole bundle).
Phil
philbrown
Post by philbrown »
Phil O wrote:Phil, I'm not sure what you mean by spittiness. Is it the over emphasis of consonants at the beginning of a word? Are your compressors not fast enough to catch those? (I'm just speculating, here.) If by chance you do need something faster, try Rocket from Stillwell. It's got attack times in the microsecond range. It's also got side-chain capability. There's a free demo and I think it costs about $50 for individual license.
Phil
The 'spittiness' is hard to describe verbally and I can't post anything. There are some consonants as you describe, but it's more of a general 'over modulation' of high mids and highs. You could sum it up with 'harshness in the mids-highs' I guess.
I'm a huge Stillwell fan, and The Rocket is THE deal for fast compression, Phil's agree! But the faster comps (I used The Rocket in earlier years on this stuff) and 1176 styles haven't worked for me on this material as they tend to accentuate the harshness that I'm trying to describe. I may try some of these again though, as I'm way more light-handed with compression than years past (combined with a ton more volume automation these days). I'm dealing with everything form barely a whisper to shouting on this stuff and if you try to compress it into submission it gets really ugly. The way-more volume automation I'm doing these days with lighter compression- it's a whole different thing with more subtlety than SLAM! I SQUASH YOU, UNRULY SIGNAL! And there's a lesson there for music as well for unruly dynamic tracks, as many here know very well! Also, combining two compressors *occasionally* is a wonderful thing if you can get some the timing and grab differences to make friends with each other.
Right now I'm using Native Instruments Solid Bus Compressor into Waves Linear Multi-band both used sparingly and it's sounding pretty good. Still more stuff to try next week on the next job. I can really hear the difference between the linear and 'normal' EQ's/Multi-band comps these days, although that's another one that's hard to describe verbally and the math overshoots me as well.
Many thanks for the great input from you fine MOTU Nation'ers!
billf
Post by billf »
Phil, one I just found out about yesterday is Klanghelm. It's only $25 but looks like it is a beast. There is a free cut down version, so that is one more option for you.
http://www.klanghelm.com/MJUCjr.php
Robert Randolph
Post by Robert Randolph »
billf wrote:Phil, one I just found out about yesterday is Klanghelm. It's only $25 but looks like it is a beast. There is a free cut down version, so that is one more option for you.
+1 Klanghelm is awesome
MJUC is quite awesome, but DC8C is my favorite compressor plug-in of all-time. You can do so much with it in advanced mode (read the manual!) that it's my goto compressor any time I don't have a very specific sound in mind.
DC8C allows some exceptionally clean sounds, however you do have to know how to operate it. It's one of the most tweakable compressors out there.
rnappi
Post by rnappi »
+2
Tony's genius is only outdone by his generosity.
rich
2012 Mac Pro 3.46 Ghz Westmere 12 Core_96G Ram_OSX 10.12.6_DP 9.5
billf
Post by billf »
+2
rich
His saturation plugin looks incredible too. These are the sorts of companies I like to support.
philbrown wrote:
Phil O wrote:Phil, I'm not sure what you mean by spittiness.Phil
My 2 cents' worth:
Spittiness, IMHO, is epitomised by what T-Racks used to do to the vocal high end back in the early days. This manifested as high-end crunchiness in cymbals. Can't speak for today.
