ADAT Selector/Splitter
I have a HearBack system that takes ADAT. I have two ways of feeding my headphone mixes when I'm either tracking simple small sessions or larger full band sessions.
I send ADAT from my Tascam DM24 to the Hearback and I also send it from my 2408 for using CueMix.
Is there a box that takes 2 ADAT input signals and has a selector to which ADAT input gets sent to the output?
Sort of like an A/B switch but for ADAT 8 channel lightpipe.
Anyone know of such a thing?
Dual Quad-Core 2.8 GHz Mac Pro 3,1 • Yosemite • 24 GB RAM • MOTU 2408mk3 (x's 2) • DP 10.xx • Finale 25 • Logic • PT 12 • +outboard gear
Re: ADAT Selector/Splitter
A box with a manual switch? There's the discontinued M-Audio Digipatch.
http://ems.music.utexas.edu/docs/DigiPatch_Manual.pdf
You already have a device that can switch between multiple banks of ADAT-8 in to ADAT-8 out, however. It's your 2408. It will do exactly what you want in stand-alone mode or when connected to the PCI-424 card.
When connected to the 424, it shouldn't be hard to set up multiple CueMix profiles that do exactly what you want.
that's something like what I'm looking for.
I wonder if there's a 2x1 box somewhere out there. I just can't crawl back in the back of my gear every time I wanna switch.
on gearslutz, they said this will work...
http://www.monoprice.com/Product?c_id=1 ... 1&format=2
can anyone verify?
can anyone verify?
Looks like a passive optical routing device... the proverbial (smoke and) mirrors. Should work fine.wonder wrote:on gearslutz, they said this will work...
can anyone verify?
Yes. Just a passive switcher.
I ordered one. We'll see.
Did the optical switch work for 8 channel ADAT? There's a surprisingly low amount of info on the ADAT compatibility.
Big love
P
Big love
P
It did.
Although I eventually ditched it because I wasn't using it much if at all. And I think a couple times it didn't sync very well.
I yanked it a while ago and have almost forgotten about it.
