It is currently Fri May 24, 2013 8:33 pm
Text Size
whats a good audio editing software
Postby coonsanders » Mon Mar 26, 2012 7:28 pm
hi gang
i need a decent audio editing software for 78 records..if u know of any good
ones can you send me some good namebrands?thanks
coonsanders
coonsanders
Re: whats a good audio editing software
Postby coonsanders » Mon Mar 26, 2012 7:29 pm
i forgot mention it should be mostly 4 78s
coonsanders
coonsanders
Postby MIDI Life Crisis » Mon Mar 26, 2012 9:47 pm
What bridge?
_______________________________________________________________________
_____________________________MIDI Life Crisis_____________________________
_____________ML.3 • DP 64 bit • 8 core MP/20GB RAM • Track 16______________
Postby coonsanders » Tue Mar 27, 2012 3:54 am
hi
what do u mean by "what bridge"?
coonsanders
coonsanders
Postby MIDI Life Crisis » Tue Mar 27, 2012 7:21 am
What platform? Mac or PC?
Are we talking recording software or restoration software? DP is great recording software but has very limited noise reduction. I don't know where you might find that but I think Logic Pro (if you're on a Mac) has some noise reduction. If you're on a PC I don't know the answer.
Restoration software such as Sound Soap has a record feature and I'd go with that for sure. The light version might be OK, but for fine tuning your work the pro version runs about $600 last time I checked.
http://www.bias-inc.com/products/soundSoapPro2/
There are less expansive such as Izotope Music & Speech Cleaner (with record function) but compared to Sound Soap, it would be like using a sledge hammer instead of a scalpel.
Postby coonsanders » Tue Mar 27, 2012 8:30 am
hi
im on a pc..the soundsoap i have isnt pro its just a basic noise reduction.
i use nero to put the files from my turntable into the computer..then i use
click repaire AND THEN i use sound soap to clean up the files...or try too..
lenny
coonsanders
Postby FMiguelez » Tue Mar 27, 2012 8:52 am
Steinberg's Wavelab works for both platforms, and I've heard good things about it.
Mac G5 dual 2GHz/4 GB RAM / OSX 10.5.8 / DP 7.24
Tascam DM-24, Yamaha 01v, MOTU 2408 MK3, MOTU MTP AV USB, all Spectrasonics' stuff,
Vienna Instruments SUPER PACKAGE, Waves Platinum, slaved Macs running VI Pro and VE Pro
“In physics the truth is rarely perfectly clear, and that is certainly universally the case in human affairs. Hence, what is not surrounded by uncertainty cannot be the truth.” ― Richard Feynman
FMiguelez
Postby coonsanders » Tue Mar 27, 2012 8:55 am
hi
i was told thats its not really made for what i want to do..thanks..
coonsanders
coonsanders
Postby rhythm_kitchen » Wed Mar 28, 2012 9:57 am
http://www.waves.com/content.aspx?id=201
I would get a linear DAW for PC that'll support Waves Version 9 Plugins?
There's list of supported DAWs at Waves website (version 9 requires your own Thumb Drive to be mounted or their plugin will not instantiate. You are going to clean up the mono files right? Burn them from a track? That's pretty much common now with DP and other DAW software.
iTunes to convert to MP-4 or wave-lossless. Personally I have compared MP-4 to lossless and the hi-end + room ambience is still there in wave lossless or Apple lossless only 3x size of MP-4.
Also there is a VST plugin you can buy to edit wave meta-data directly or broadcast wave for 78 catalogue number, artist, composer, arranger, band name. I have some Al Jolson DECCA 78 Acetates and there's a lot of info on the label (they sold with just a plain vanilla cover as you know).
DL DVD +R media is cheap. DVD -R is cheap. CD-R media is cheap. But you want at minimum Verbatim Media or Tayo Yuden. Both are considered archival quality manufacturers of Optical Media (Do not burn DL +R on -R and Verbatim is you only option Yayo Yuden doesn't make it (yet) search under JVC.
http://www.supermediastore.com/
You can tell if it is genuine Tayo Yuden as it has a threaded center spindle. They don't make a Dual layer +R media (yet). Only single layer DVD -R or CD-R.
Do you have a good hot CD-R burner like Plextor or Yamaha? These are (were) sold in a case with a fan as they produce a lot of heat.
Years ago Gold Media from Ampex was sold as Quantegy Gold. But the trend now is Tayo Yuden which is still made in Japan. HP occasionally resells, repackages Tayo Yuden under HP brand, so look for HP media with a threaded center spindle (not the twist on cap that is common).
Last edited by rhythm_kitchen on Fri Mar 30, 2012 7:26 am, edited 1 time in total.
rhythm_kitchen
Postby coonsanders » Wed Mar 28, 2012 10:08 am
hi
is x-crackle a freee software?
coonsanders
coonsanders
Postby stephentayler » Wed Mar 28, 2012 10:18 am
X-Crackle, Waves, currently $300
http://www.chimera-arts.com
http://ostinatomusic.com
http://stephentayler.com
Mac Pro 8 Core 2.8Ghz 16Gb RAM, MacBook Pro, 2Gb RAM, OSX 10.8.2, DP 8.01, PT9.06, Logic 9.1.8, MOTU Traveler, Ultralite Mk 3 Hybrid, MC MIx, MOTU VIs, Waves, Izotope Everything, Spectrasonics, SoundToys, Slate, Softube, NI Vintage Compressors, spl Surround Monitor Controller, spl Auditor Headphone amp, Genelec 1031A, 1029 5.1 system, Sontronics Mics, iPad etc..
stephentayler
Postby MIDI Life Crisis » Wed Mar 28, 2012 10:41 am
You will not find a legally free or even cheap solution.
Postby coonsanders » Wed Mar 28, 2012 12:16 pm
thanks guys
coonsanders
Return to General Recording
Who is online
Who is online
In total there is 1 user online :: 0 registered, 0 hidden and 1 guest (based on users active over the past 5 minutes)
Most users ever online was 145 on Wed Oct 31, 2012 7:14 am
Login Form
