Variax Owner, I've got the cheapest best DI for you
by Dwetmaster » Fri Mar 13, 2009 9:48 am
Having decided to choose Amplitube instead of the pod for my variax, I was looking for a good DI to get the variax's signal to the computer. I almost bought a radial for a few 100$ when I read somewhere that the variax ethernet connector was sending spdif directly. So after a few research on the net I got the variax Pinout. From there, you're a few dollars away of having the cleanest signal chain from the variax to the computer. All you need is a spdif in on your interface. My 896HD doesn't but I had an audiofire that was sitting there.
So All you need is an ethernet cable, a 7V 2Amp power transformer, everything to get the guitar connected to RCA and to power, and you'Re good to go for about 20$
I spent a bit more as I wanted to make my connecting device clean. For about 50$ I got this:
- I teared apart and old Behringer EQ that wasn't working anymore (duh...
) to get a rackmount enclosure.
- a blank Rackmount plate
- A female Neutrik Ethernet connector
- An AC illumintated switch, AC Socket with fuse
- I got a regulated power transformer at en electronic supplier. I got one that's made for video cameras and it look fairly protected.
- Two neutrik socket for my ethernet cable to properly connect my guitar to my "Digital DI"
- A few other minor parts to get everything assembled properly.
Here's the pinout for the interested:
2: PWR (7v)
1: GND
4: Spdif-
5: Spdif+
8: RX-
7: RX+
6: TX-
3: TX+
The RX & TX are used for Line 6 workbench so I didn't connect them.
2: PWR (7v)
1: GND
4: Spdif-
5: Spdif+
8: RX-
7: RX+
6: TX-
3: TX+
MacPro 8Core 2.8GHZ 16GB RAM OSX10.6.8
MacBook Pro 17" Unibody 2011 OSX10.7.4
MacPro Nehalem QUAD 2.66GHZ 6GB RAM OSX 10.6.8
DP7.24-DP8.01, Bidule, M5 3, Ethno 2, BPM 1.5 Kontakt4, BFD2, SD2, Omnisphere, Wave Arts P-S5, Altiverb7, PSP VW & OldTimer, VB3, Ivory 2 Grand, True Pianos, Ozone 4, Reason 4, AmpliTube3, Bla bla bla...
A few El & Ac basses, Variax300, Hammond A-100.
Dwetmaster - Posts: 3340
Re: Variax Owner, I've got the cheapest best DI for you
by Dwetmaster » Mon Sep 14, 2009 9:53 am
I'll bump this as it is relevant to DP7's guitar amp emulation.
• Page 1 of 1
Who is online
Users browsing this forum: No registered users and 2 guests
- Board index
- The team • Delete all board cookies • Delete style cookies • All times are UTC - 7 hours
