It is currently Sat Feb 17, 2018 12:32 pm
Text Size
Switched computers, now BPM wont play BPM samples
Moderators: James Steele, ssp
Postby chlorinedream » Wed Jun 07, 2017 12:26 pm
Hi - I tried loading up BPM on a new Mac with a valid license on the iLok and the BPM soundfiles in the appropriate location in the Library directory and get the following error:
"BPM soundbank is required but currently missing or no valid authorization could be found. Please check your setup".
As far as I can see everything is setup properly. The Beatbox Anthology samples load fine. Any ideas?
Maybe it's time to move on from BPM. What are people using nowadays?
__________________________________________________________________________________
iMac 27" (14,2 Late 2013), 3.5 GHz Core i7, 32GB Ram, OS 10.12.3, MOTU 828mkIII, 1TB SSD, DP 9.12, MachFive, BPM, SoundToys, Izotope, ValhallaDSP, Virus TI, Omnisphere
chlorinedream
Re: Switched computers, now BPM wont play BPM samples
Postby mikehalloran » Wed Jun 07, 2017 1:43 pm
Not nearly enough information.
What OS was the old Mac? How did you move the samples over?
July 2010 iMac 2.93G i7 Quad, OWC eSATA mod, 32G RAM, OS 10.13.1
828mkII FW; MOTU MTP/AV USB with Firmware 2.0.1; DP 9.5.1; IK-NI-Izotope-PSP-Garritan Antares, 32Lives, MachFive 3.2.1
LogicPro X 10.3.2, Finale 25.5, 2014.5, Encore 5.0.7, Notion 6, Overture 5, TwistedWave 1.18, DSP-Q 4.4, QuickTime Pro 7.6.6, SmartScore Pro X2 10.5.5, Toast 16
Test machine: G4-1K Dual Processor: OS 10.4.11 / OS 9.2.2; DP 5.13; Encore 5.05 & 4.5.5; Toast 9.07b, legacy apps
Postby chlorinedream » Wed Jun 07, 2017 3:16 pm
Motu support quickly diagnosed the issue. For some reason I had an older version of one of the BPM soundbanks installed. Replaced with the most current one and it works fine.
chlorinedream
Return to BPM (General Chat)
Who is online
Who is online
In total there is 1 user online :: 0 registered, 0 hidden and 1 guest (based on users active over the past 5 minutes)
Login Form
