It is currently Fri Dec 15, 2017 12:35 pm
Text Size
pads play mode settings
Moderators: James Steele, ssp
Postby Javus » Thu Apr 28, 2011 9:02 pm
Hi all,
I would like the sample to finish when my MIDI note in my host finishes or when I let go of the note. I think its called 'note-off' instead of 'one-shot'.
example, If I have kick drum sample loaded into pad "BD1" if tap the MIDI note I just want it to play the very start of the kick, not the whole sample.
On Ultrabeat it is called 'gate' if your fimiliar.
Is this possible with BPM?
Javus
Re: pads play mode settings
Postby carrythebanner » Fri Apr 29, 2011 6:49 am
Try adjusting the amplitude envelope. By default most pads uses an AHD envelope, but you can switch them to ADSR as you please.
carrythebanner
Postby Javus » Sat Apr 30, 2011 1:52 am
thanks I do use the ADSR/AHD to get the sound I like but I was hoping BPM can play the sample as long as the MIDI notes length in my DAW - logic.
So this is not possible with BPM?
Javus
Postby Javus » Sun May 01, 2011 7:25 am
anybody?
Javus
Postby grassrootking » Mon May 02, 2011 6:29 am
If you set the release value to "0" using the ADSR envelope it will do what you want.
-GK
grassrootking
Return to BPM (General Chat)
Who is online
Who is online
In total there is 1 user online :: 0 registered, 0 hidden and 1 guest (based on users active over the past 5 minutes)
Login Form
