Turning Input Quantize on and off
JSmith1234567
Post by JSmith1234567 »
Am I missing something...is there no key-command to turn input quantize on and off?
Re: Turning Input Quantize on and off
Looks like you are correct. You can assign a command to open the window, but you have to click on the checkbox to enable it. A third party macro program might be able to fill in that last step. I.e., you'd use the COMMAND to bring the window to the front, then have the macro execute a click in that window at a certain point relative to the upper left corner, then the macro would dismiss the window. This could be used to toggle it on/off.
The option to insert a MIDI plugin to quantize is a reasonably fast alternative, but it doesn't help with making editing and/or notation functions work as you might want.
KenNickels
Post by KenNickels »
Very annoying that this is not in Preferences. So many things that could reduce the tedium of DP should be there, yet they're not.
My Box(s): Two Mac Pros 5,1/3Ghz, 12 core, 96GB Ram, OS 10.14.6, One Windows 10 computer, Vienna Ensemble Pro, MOTU Audio Express, DP 10.01, Falcon 3, Eastwest, NOVO Strings, 8Dio Brass, Spitfire,, Symphobia
JSmith1234567
Good idea about using a macro...I'll do it with Keyboard Maestro.
Thanks again.
