Pitch shifting effecting all versions of a soundbite
I can't figure this out. I have a set of soundbites and I don't want them shifted in the first chorus, but there is a key change for the second chorus so I want them shifted there but when I change the pitch for the soundbites in the second chorus, it changes the chorus. When I cut and paste I don't have an option to great new versions of the soundbites. Anyway theoretically I should have to because it is non-destructive, right. I am totally lost. How can I pitch shift them in one place and have them unaffected in another? Thanks.
Krakadon
aka Dave Williams
Rock, metal, Camas, WA
* 15" Mid-2019 MBP 2.4 GHz 8-core i9, 32GB RAM, Ventura 13.6.5. TB: UA Apollo QuadFW w/TB card, Satellite OctoTB2 & OctoTB3, PreSonus Quantum 4848 TB2; USB 2.0: Ext USB3 drives, Fractal Audio Axe-Fx III , Revv Generator 120 MK3; USB 3.0: Stream Deck XL, M Audio Oxygen 49, Akai MPD218, Console One Mk3, SSL UC1, X-Touch U; HDMI: 34" 16:9 & 32" 2K Monitors
* DP 11.31
aka Dave Williams
* DP 11.31
Re: Pitch shifting effecting all versions of a soundbite
Never mind, I figured it out. I selected the second set of soundbites (i.e. "clones") and used "Duplicate Soundbites" to create "duplicates". It seems counter intuitive, and wasn't easy to figure out. Why wasn't that the default when I transposed them if there were copies of the same soundbite but only some selected for the edit?
Krakadon
aka Dave Williams
* DP 11.31
aka Dave Williams
* DP 11.31
- philbrown
I'm sorry I can't supply a page number at the moment but if you look up 'Edge edit copy' in the user guide there's a whole section that explains MOTU's approach and why you're experiencing what you are.
- buzzsmith
Another fairly quick option is to go to that second chorus and do a slight edge edit on all of the tracks with the Option key held down. That creates a new soundbite for each track and they're no longer tethered to the original.
Buzzy
Buzzy
Yamaha C7 Conservatory Grand
Hammond B-3 / Leslie 145
Focal Twin6 Be(s)
Focal Twin6 Be(s)
regarding this, I don't know if it's a bug or not. But if you enable "edge edit copy" and copy a soundbite and change the pitch, it still changes the pitch in the original soundbite. However, if you do it the way buzzsmith describes it, it works.
I usually have edge edit copy enabled and just merge the copied soundbites quickly before shifting pitches.
- Gravity Jim
Yeah, enabling edge edit isn't enough. You need to make the edit to create the new sound bite.
Jim Bordner
Krakadon
aka Dave Williams
* DP 11.31
aka Dave Williams
* DP 11.31
