Hi,
Is there anyone here knows how to route Voxengo Span?
I am playing pink noise on one track and return with mic through my 2408mkll input into my DP.
Span is on master track so I can see the graph of the pink noise file but the mic return I don't know how to route it to Span to compare.
P.S I am trying to turn my room with pink Noise. Hope someone can help. Thanks.
Regards
Johnson
Voxengo Span
Re: Voxengo Span
If I understand the question, you should be able to open another instance of Span as an effect on an audio track, and while making sure the input monitor button is enabled, monitor the mic audio there.
