quick way to switch between on/off for VI windows?
rockman413
Post by rockman413 »
Hi I have 2 displays. one is my tracks view/MIDI editor, one is the mixer window.
It always take me some time to open the Kontakt, and close it with command and W.
When I use logic, I can one click "V" to open and close all VI windows. Your suggestions of how we can quick switch?
macbook pro 10.10, 2.5G,16G ram,256G SSD
FMiguelez
Re: quick way to switch between on/off for VI windows?
Post by FMiguelez »
Click on the little "V" icon in the bottom left of the mixer. That toggles between V'Racks and chunk tracks.
Is that what you mean?
rockman413
FMiguelez wrote:Click on the little "V" icon in the bottom left of the mixer. That toggles between V'Racks and chunk tracks.
No, that' not what I mean.
I mean, if I have a 3rd display, then I can put the VI windows there and that's easy . But I don't have a 3 rd display, how can I easily one key shortcut to open the VI I want and close all VIs so I can easily see the mixer and my tracks.
wvandyck
Post by wvandyck »
rockman413 wrote:
...I can one click "V" to open and close all VI windows. ?
⌃⇩O = Open Selected Effects
⌃⇩⌘W = Close All Effect Windows
You can change both Commands to 'V'.
Select a plug-in window in a mixer or channel strip insert. V to open, V to close.
Several selected plug-in windows will open but immediately afterwards only one them remains selected. In this case you can use V to close all open effects windows them but you would need to select the others to invoke the open - V- command.
You can also view different plug-ins one at a time using the Insert A etc. popup, similar to the linked window function in the other application.
rockman413
Thank you. Very helpful ! Is there a One Key command to open all Vsti windows?
wvandyck
Post by wvandyck »
I'm pretty sure you have to first select the plug-in inserts, then invoke Open as above.
