Audio bite gain on duplicated clip
How do I change the audio bite gain on a duplicated clip without affecting the original clip. I alt-dragged the orginal clip which I though created a new discrete clip. But every time I make an audio gain change the original clip follows which I don't want. Any advice? Thanks.
- FMiguelez
Re: Audio bite gain on duplicated clip
Use the command key for this.
You can also turn Edge Edit Copy on or off as needed in the GE Mini-menu. The command key will temporarily defeat whatever setting you have here.
- philbrown
As an addendum to what FM said, if you're in DP 9, p 353 of the DP user guide about Edge Edit Copy is really worth reading and absorbing.
