DP 9.5 issues?
DP 9.5 issues?
I'm starting a job for which I'm needing to do a bunch of time stretching / pitching. I figured it might be a good time to jump from DP 9.02 to 9.5 since they now have the ZTX stretching etc.
Does anyone know of any compatibly issues between 9.5 and various plugins / VIs?... Especially NI, Spectrasonics, Output, VSL VEPro 5, Waves, Altiverb, Soundtoys, Fabfilter, Ohm Force, Audio Damage, etc.
thanks!
thanks!
Main SYS: 12-Core New Mac Pro (Dec 2013), 64GB RAM, OS10.10, Apollo Quad Interface, 3xSSD work/sound drives in TB Enclosure, UAD Plugs, DP, VE PRO, All NI, All Spectrasonics, many libraries, VIs etc.
2nd SYS: Intel 8-Core Mac Pro (2007), 28GB RAM, OS10.7, MOTU PCI 424, 2408 interfaces (4), DP8.07, VE PRO, All NI, All Spectrasonics, many libraries, VIs etc.
2 Mac Minis (2011): Dual Quad, 16GB RAM running VE Pro, various libraries in Kontakt, G-Player, UVI.
- philbrown
Re: DP 9.5 issues?
I get consistent crash-on-quits and almost always Waves comes up by name in the crash report. I'm in the middle of a classic stalemate between Waves and MOTU though, so nothing is getting done (that I know of). Other than that, no problems. You can have both versions installed and jump back if you see any issues.Chris T wrote:I'm starting a job for which I'm needing to do a bunch of time stretching / pitching. I figured it might be a good time to jump from DP 9.02 to 9.5 since they now have the ZTX stretching etc.
thanks!
Re: DP 9.5 issues?
I removed all things Waves from my system several years ago. Solved many problems, especially crashes. I think DP has crashed twice in 4-5 years and usually right after an update. It's like a ritual. Install. One crash. Reset PRAM. No more crashes, and certainly no Waves crap installed ever again. Used to also repair permissions but that no longer is a thing AFAIK.
I think Shooshie might have something to say about this. BTW, Phil, how's the stab wound?
- philbrown
Re: DP 9.5 issues?
Don't have a clue what you're referencing there.MIDI Life Crisis wrote:BTW, Phil, how's the stab wound?
Re: DP 9.5 issues?
9.51? No problem. OS 10.13.1 gave me a couple of hitches:
I had the license server error once with 9.51 and High Sierra — weird because I had trashed the older Dock shortcut and reset it to 9.51. Removing 9.5 and reinstalling 9.51 fixed that (they do share resources). Other than that, smooth sailing here.
Even older plugs that need 32Lives still work. According to SoundRadix, they’re not supposed to. I tried reinstalling a few that I had removed earlier as a test and 32L is unable to wrap new ones. JBridge no longer works at all. I’ll live.
Re: DP 9.5 issues?
Lots of Phils around here:philbrown wrote:Don't have a clue what you're referencing there.MIDI Life Crisis wrote:BTW, Phil, how's the stab wound?
viewtopic.php?f=9&t=64119
Re: DP 9.5 issues?
I'm running DP9.51 successfully using MOTU, Waves, NI, Spectrasonics, Synthogy, Soundtoys, AudioEase (Altiverb), IK, UA, Eventide and more.Chris T wrote:I'm starting a job for which I'm needing to do a bunch of time stretching / pitching. I figured it might be a good time to jump from DP 9.02 to 9.5 since they now have the ZTX stretching etc.
thanks!
Before you install 9.51, rename DP9.02 to "DP9.02"; that way it won't be overwritten and you can use it if you encounter issues. I have noted and reported to MOTU issues with older projects improperly converting pitch data when opened in 9.5 and 9.51. Otherwise, 9.51 has been pretty stable for me. I've had maybe two crashes in a week+ of solid use.
HC Markus
Re: DP 9.5 issues?
Lol. I've had my fill of phils.cuttime wrote:Lots of Phils around here:philbrown wrote:Don't have a clue what you're referencing there.MIDI Life Crisis wrote:BTW, Phil, how's the stab wound?
- Gravity Jim
Re: DP 9.5 issues?
Likewise. I've been running it under beta version of 10.13, 10.13.1, and now the release version of 10.13.1. Not a hitch. My system hasn't flipped out even once in the last month.HCMarkus wrote: I'm running DP9.51 successfully using MOTU, Waves, NI, Spectrasonics, Synthogy, Soundtoys, AudioEase (Altiverb), IK, UA, Eventide and more.
Jim Bordner
Re: DP 9.5 issues?
Not quite on topic, but since I just discovered it in DP9.5, can anyone clear this up for me:
On looking a the new "Effect Performance" window, where I can (very usefully!) see the relativee processor drain made by each VI / plugin, it appears as though all my DISABLE plugins are still using processor (especially Soundtoys Decapitator). Is it true then that, even when disabled, plugins are using up processor power?...
thanks
thanks
Re: DP 9.5 issues?
If, by "disabled", you mean bypassed but still instantiated within a track that is not truly disabled (un-check the round blue button that completely turns off a DP track), yes.Chris T wrote:Not quite on topic, but since I just discovered it in DP9.5, can anyone clear this up for me:
thanks
Plugins must continuously process audio to allow turning bypass on and off (manually or using mix automation) without glitches. As such, even when bypassed, plugins use CPU horsepower.
If you want to kill the CPU hit, disable the track in question using the round blue button. But don't expect the track to come back to life during playback without some audible disruption.
