Hi.
I keep getting and authorization error message when loading a DP project about a number of Slate plug-ins I don't own ( for instance "FG-Bomber", whatever that is, is one of them).
I do own a few of their VCC plug-ins, but not these particular ones.
Is there a way to totally delete them to stop DP asking for them on startup?
Slate must install them when you by other plug-ins from them?
Slate Plugins / DP / Startup Errors
Re: Slate Plugins / DP / Startup Errors
Go to the Slate website - www.slatedigital.com, and send a support ticket to tech support.
They are very good about answering.
You have a problem that might be unique to your system or situation. I have a subscription to
Slate Everything bundle and also own a few of the plugins outright. I have never seen an alert like
the one you reported.
http://www.davepolich.com
- philbrown
Maybe check your components folder and remove them if they're there:
Finder > Hold option key > Go menu > Library > Audio > Plug-ins > Components
If VST then that folder is also in the Plug-ins folder along side 'Components'.
I use my Components folder so much (and it's buried pretty deep) that I keep it in my sidebar in the Finder.
Hey thanks!philbrown wrote:Maybe check your components folder and remove them if they're there:
I should have thought of that.
I'll do that.
