Page 4 of 9
Re: DP 9.5 IS NOW UP!!! :)
Posted: Wed Sep 13, 2017 7:11 am
by JSmith1234567
dix wrote:Do we have now a global option to run them in real time by default, or that hasn't changed?
No change. No global run-plugins-real-time setting.
Bummer!
That was the ONE thing I was waiting for.
Guess I'll stick with 9.03.
Why they can't fix this is beyond me?
Posted: Wed Sep 13, 2017 7:48 am
by bayswater
RodneySauer wrote:Klaus wrote:Lazy me...
Has anyone compared the new time/pitch to Melodyne 4 ?
esp. the ability to do it with multiple tracks ?
I don't have Melodyne, but DP 9.5 does work with a selection of multiple tracks, though it loses cross-fades (see my post above).
I've done some time/pitch with IRCAM and Melodyne and found IRCAM worked better, even with changes in the 10% range. Do you think the Zynaptic algorithms worked better for you than IRCAM?
On crossfades, I found (in 9.5) edits that changed the relative position of the soundbytes, might make fades and cross fades disappear. I can see why cross fades, which are bassed in part on the overlap would be affected, but don't understand why simple fades would be affected. In most cases, I wanted to redo the fades anyway so it's not a big issue for me.
Posted: Wed Sep 13, 2017 8:57 am
by Klaus
bayswater wrote:RodneySauer wrote:Klaus wrote:Lazy me...
Does IRCAM multitrack ?
Posted: Wed Sep 13, 2017 9:27 am
by bayswater
Don't know, they might have a product that does. I used it on a two track recording to change key and tempo for someone that wanted to add new tracks. Worked well for that.
Posted: Wed Sep 13, 2017 9:37 am
by RodneySauer
I was using the IRCAM algorithms included in MachFive, which only works on stereo files. I don't have the stand-alone IRCAM program.
Another cool thing about the DP 9.5 scaling is that you can apply it with a tempo-change ramp, so you can change tempos gradually, or in just part of a piece, with gradual transitions. I saw it on their demo video, but I'm going to have to learn how to actually accomplish it...
Posted: Wed Sep 13, 2017 10:03 am
by bralston
I would also encourage folks with the pitch shifting to try out both the formant correcting ZTX one and the standard ZTX. Don't assume the formant correcting one is best for everything or vise versa. The ZTX standard will probably do better on stereo polyphonic stuff (say an orchestral recording already mixed)...just really depends on the material though. But it is an easy thing to switch and try soundbite by soundbite.
Posted: Wed Sep 13, 2017 12:01 pm
by Gravity Jim
Haven't had time to experiment with ZTX yet, but the Effects Performance window is already my new favorite thing about DP. One of those things that, when you see it, it makes you think, "Why didn't it always do that?"
Posted: Wed Sep 13, 2017 12:27 pm
by RodneySauer
bralston wrote:I would also encourage folks with the pitch shifting to try out both the formant correcting ZTX one and the standard ZTX. Don't assume the formant correcting one is best for everything or vise versa. The ZTX standard will probably do better on stereo polyphonic stuff (say an orchestral recording already mixed)...just really depends on the material though. But it is an easy thing to switch and try soundbite by soundbite.
And no, there doesn't seem to be a universal preference setting to decide what kind of ZTX you want to use (formant correcting or standard). Open the Soundbites window. Select the bites you're interested in (or select one then press command-A to select all). On the contextual menu (control-click to reveal it) choose Sound File Information. (Somehow, that command is not on the popup menu of the Soundbites menu, just the contextual menu and the main "Studio" menu). There's an item in the Sound File Information menu called "Transpose," and that's where you can select how you want transposing handled. There are also some popup menus with presets for "ZTX Pitch Play Quality" and "ZTX Offline Quality," but I can't find any information about what those settings mean...
Posted: Wed Sep 13, 2017 12:49 pm
by dix
Preferences > Audio Options > Default Transpose Mode For New Soundbites
Posted: Wed Sep 13, 2017 1:03 pm
by RodneySauer
Posted: Wed Sep 13, 2017 1:07 pm
by Klaus
Maybe I missed links…
are there any videos around about how to use the new time/pitch in DP 9.5 ?
Klaus
Posted: Wed Sep 13, 2017 1:12 pm
by RodneySauer
Posted: Wed Sep 13, 2017 1:23 pm
by Babz
Holy f^ck! Where have I been? I come up for air and it's Christmastime in September!
Can't wait to open my present!
Is this the first time we've seen a x.5 update?
Posted: Wed Sep 13, 2017 1:39 pm
by HCMarkus
Babz wrote:Holy f^ck! Where have I been? I come up for air and it's Christmastime in September!
Since 4.5, if I recall correctly.
Posted: Wed Sep 13, 2017 2:07 pm
by Klaus
Thanks Rodney !
Sorry not having mentioned...I was looking for multitrack manipulation videos…
Klaus
