Milliseconds Measured in Counter
JSmith1234567
Post by JSmith1234567 »
This may be a dumb question, but...
I'm trying to measure latency at different buffers and plug-ins with my setup.
I zoom way-in on peaks in the waveform editor and compare the input and output tracks.
I have the counter set to real-time.
The last part of the counter's four measurements (hours, minutes, seconds, ???).
The ??? part is; am I measuring milliseconds there, or, milliseconds x 10 ????
Don T
Re: Milliseconds Measured in Counter
Post by Don T »
Hello,
If your counter is showing 00:00:00.00 then yes the least significant readout is seconds. As in 00.00 seconds (two decimal places or in hundredths of a second.
For more accurate reading use samples. 44.1 samples = 1 millisecond @ 44.1K or .00002267 seconds / sample.
At 96k = .000010416667 seconds or 96 samples / 1 millisecond.
I always use samples when testing latency.
It's the ear, not the gear!
JSmith1234567
Hey thanks you for that!
I'll do it your way!
JSmith1234567
I'm still a little confused.
If the difference between two events is 1,890 samples, and I'm at 48k, how many milliseconds latency is there?
That is, a peak in track 1 was at 6778766 samples, and the the same peak in track 2 was at 6780656 samples, according to DP's counter set to "samples"?
JSmith1234567 wrote: how many milliseconds latency is there?
25.4
JSmith1234567
25.4
YOUCH !!!!!!!!!!!!!!!!!!!!
