External Waveform Editor
- supersonic
Question pertaining to the use of the external waveform editor and the DP one at the same time. I often use the RX6 Advanced but I also need the DP's editor for other tasks. Is there a way to be able to use both without having to be forced to choose the external editor every time I switch it off?
Music is movement in silence
Re: External Waveform Editor
Not following you. I use the DP waveform editor a lot, sometimes before processing a signal in RX 6. Normally, I need to clean the track first. To me, there's no conflict.
Whether I process a track in the stand-alone RX module or use the tools as plug-ins depends on what the track needs.
I do a lot of audio repair. I can't imagine accomplishing what I do without both DP and RX 6. With the improvements to Standard, I'm not sure that most need Advanced anymore but I'm staying with it.
- supersonic
I guess I didn't make my question clear. Here it is.
How can I launch DP's internal editor while having chosen external as default?
