From master output to master fader in the V-rack
Tomas E
Post by Tomas E »
How do I do this?
I guess I'm supposed to have a master fader in each sequence which shall be routed to the master fader in the V-rack. But I can't find any way to connect them since I can't find inputs, only outputs on master faders.
Page 749 in the DP9 User Guide wrote:run the master output of each individual sequence into the master fader in the V-Rack
Re: From master output to masterfader in the V-rack
e-snobben wrote:How do I do this?
I guess I'm supposed to have a masterfader in each sequence which shall be routed to the masterfader in the V-rack. But I can't find any way to connect them since I can't find inputs, only outputs on masterfaders.
Page 749 in the DP9 User Guide wrote:run the master output of each individual sequence into the masterfader in the V-Rack
In the sequences, route all the outputs to the hardware output you want to use. You don't have to put a master fader in each sequence. Put a Master fader in the V-Rack routed to the same hardware output. Now it controls the output level of anything that plays through that channel include tracks in the sequences. To add a Master fader to a V-Rack to add it first to any sequence, and then use "Move Selected Tracks" command (right click on the track name) to get it to the V-Rack.
Tomas E
Re: From master output to master fader in the V-rack
Post by Tomas E »
bayswater wrote: In the sequences, route all the outputs to the hardware output you want to use. You don't have to put a master fader in each sequence. Put a Master fader in the V-Rack routed to the same hardware output. Now it controls the output level of anything that plays through that channel include tracks in the sequences. To add a Master fader to a V-Rack to add it first to any sequence, and then use "Move Selected Tracks" command (right click on the track name) to get it to the V-Rack.
Thank you for a much better explanation!
In other words I didn't have to do anything else but adding the master fader to the V-rack. The output was preselected the right way from the beginning.
daniel.sneed
Post by daniel.sneed »
And enabling/ disabling the V-rack, will load/unload all plugins inserted in the Master fader. Handsome!
BTW, don't forget to set your dither plugin, if any, post fader in Master fader. Otherwise, the fader may ruin the dithering.
Tomas E
Post by Tomas E »
daniel.sneed wrote:And enabling/ disabling the V-rack, will load/unload all plugins inserted in the Master fader. Handsome!
I must try dithering to see if my mixes will rise to a level never heard before. 8)
