Yes I did, but after click on even/odd notes, nothing became selected ....stubbsonic wrote:Did you select all the notes (odds and evens, just the whole batch) first, then select that menu item? That way it knows which notes you want to process for selection.
A way to select the 2nd, 4th, 6th, 8th note in MIDI edit?
Re: A way to select the 2nd, 4th, 6th, 8th note in MIDI edit
macbook pro 10.10, 2.5G,16G ram,256G SSD
Thank you but I know this. My question is how to select the even/odd notesShooshie wrote:I'm in between hosts right now. Dropbox will no longer support inline BBCode, so I can't imbed a picture. Here's a link to the Search Dialog. Click it and you will see the grid I'm talking about.
Use the check-boxes on the grid to indicate select the notes you want to select.
You can connect them or make them separate. Lots of subtlety there. You'll have to figure it out. It's self-explanatory, plus there is the manual. But you will have to invest the time to learn to get what you want out of it.
- philbrown
You completely missed my point, but that's OK.philbrown wrote:For future reference, the help menu can... well, help.rockman413 wrote:Can you elaborate more? do you mean search feature in help? grid mode ?Shooshie wrote:Yes. Use the Search feature. For what you're asking, the answer will probably be the grid mode.
It's the rightmost menu item. I typed 'Search' and it immediately showed where it was (where cuttime indicated). The manual is searchable as well.
I was honestly trying to help in general and not specifically answer your question.
Horse —> Water —> Drink [≠]
Everyone learns differently.Shooshie wrote:Horse —> Water —> Drink [≠]
Yeah, I guess in this case a video would have been the shortest route to success. But videos take time to make, edit, and upload. Still, for people to understand the power lurking in that Search feature, it probably would take a video to get them to that "oh wow!" point, where mind is blown and you just have to learn to master the search.stubbsonic wrote:Everyone learns differently.Shooshie wrote:Horse —> Water —> Drink [≠]
The only drawback to the complex searches like this one is the time it takes to set it up the first time. After that, you've got it saved, and it's a one-click search!
It occurs to me that the OP might be working without a conductor track, that is, without actual bars and beats. In that case, this aspect of the search feature would be of no use. It depends on actual consistent locations of notes within the beats. In other words, the odd-numbered notes would have to consistently fall between locations 1/000 and 1/479, or 3/000 and 3/479 inclusive. If you haven't got a beat map, you can't search for beats!
I tell people that it's worth the time to create a beat map — Record Beats, and Adjust Beats — before editing a MIDI performance, but a lot of people are in a hurry and think it's a waste of time. The Search feature shows you how much time and frustration you can save by taking the 15 minutes or so needed to make a beat map. It doesn't have to be perfect, but once you learn WHY you are making a beat map, you get better at doing it quickly while being sure to get the notes within their beats, and not outside of them.
Shoosh
I do use a conductor's track... Plus, the DP has a function of search for even/odd notes, it's just it does not work out in my case, so I'm asking other user's experience of how to get this to work, probably I'll see where the problem is ....Shooshie wrote:Yeah, I guess in this case a video would have been the shortest route to success. But videos take time to make, edit, and upload. Still, for people to understand the power lurking in that Search feature, it probably would take a video to get them to that "oh wow!" point, where mind is blown and you just have to learn to master the search.stubbsonic wrote:Everyone learns differently.Shooshie wrote:Horse —> Water —> Drink [≠]
Shoosh
I still could not make it work ... Help!
Rockman, I've used that very thing — select odd beats — within the past few months. Worked fine. I do not remember if I tweaked it first. But it worked. What more can I do? I just don't know what else to tell you. Have you mastered the grid? Do you understand the check boxes for "pairs of checked points form ranges?" and "include start point / end point?"
What about Boolean operators: and, or, & not? Are you using those correctly? I don't know your experience level with database technology, so I don't know if you're missing something in the way you are searching, or if something truly is broken. All I can say is to review your technique and make sure you haven't missed a single box in the interface.
Shoosh
Shoosh
1. Describe your exact process step by step, including what kind of notes you are selecting, how you are selecting them.rockman413 wrote:I still could not make it work ... Help!
2. Describe exactly what you see in the search window
3. Describe exactly what result you get (i.e., nothing happens, no notes selected, etc.)
