Activity Monitor / How to use it ???
I'm trying to optimize my 6-core Mac Pro, which is running DP and VE Pro server.
When I open Activity Monitor and pick the memory tab, I see that I still have free memory with my DP template and my large VE Pro template.
When I switch to the CPU usage tab in Activity Monitor, I see all sorts of crazy numbers.
The % CPU column shows percentages for DP and VE Pro way over 100 %.
At the same time, the System/User/Idle box on the lower left show around 80 % idle at the same time.
The little bar-graph does it's own thing.
How does this all work?
How do you interpret any of this?
Re: Activity Monitor / How to use it ???
Don't put large multiple instruments in a single instance of your VI. Smaller instruments can be in one VI, but if you have several instantiations of the VI, each one will address a different core of the machine. Single instances only address a single core. So if you spread the VIs out over 6 instances, you'll use all six cores and the CPU will not get bogged down trying to do the same job with access to a single core.
That doesn't answer your question, but it may solve your problem. It's called multi-threading and DP takes good advantage of it. Rule of thumb: Each large VI instrument should have it's own fader in the mixer (or v-rack).
Thanks to MagicD at MOTU for that tip.
I believe that, because your CPU has six cores, full utilization of all cores will read as 600%.JSmith1234567 wrote:I'm trying to optimize my 6-core Mac Pro, which is running DP and VE Pro server.... When I switch to the CPU usage tab in Activity Monitor, I see all sorts of crazy numbers. The % CPU column shows percentages for DP and VE Pro way over 100 %.
and thank YOU for that tip !!!MIDI Life Crisis wrote:Don't put large multiple instruments in a single instance of your VI. Smaller instruments can be in one VI, but if you have several instantiations of the VI, each one will address a different core of the machine. Single instances only address a single core. So if you spread the VIs out over 6 instances, you'll use all six cores and the CPU will not get bogged down trying to do the same job with access to a single core.
that makes more sense to me now. thanks!HCMarkus wrote:I believe that, because your CPU has six cores, full utilization of all cores will read as 600%.JSmith1234567 wrote:I'm trying to optimize my 6-core Mac Pro, which is running DP and VE Pro server.... When I switch to the CPU usage tab in Activity Monitor, I see all sorts of crazy numbers. The % CPU column shows percentages for DP and VE Pro way over 100 %.
One optimization is to make sure you use your RAM to the fullest by maximizing pre-load of VI sample sets. One member here questioned whether doing so results in real-world performance gains, and I can only offer my subjective impression of smoother operation. Regardless, the concept sounds good in theory...
Here's the thread:
viewtopic.php?f=26&t=63621
Have fun!
Here's the thread:
Have fun!
HC Markus
