Sync audio to tempo (realtime) ?
dactarus
Post by dactarus »
Hi,
I have a basic chunk with a Stylus instr (sync to host) and an audio looped track.
Is there a way to change the chunk's tempo (live) and having the audio stretched in real time to stay synced ? I've never worked this way, I don't knows if DP does ?
Thanks,
Emmanuel
Re: Sync audio to tempo (realtime) ?
Stretch tempo on an audio file is going to have a processing time lag, so you'd have to request the change well in advance. If you knew ahead of time what the new tempo will be you might just trigger the soundbite another way, it realtime processing will need some time to process, even on the fastest machine.
2013 Mac Pro 32GB RAM
dactarus
Post by dactarus »
Thank you. For now, I moved my audio loop into Stylus (> Rex file), an acceptable workaround for my needs today.
Emmanuel
