DP pan law?
- FMiguelez
DP pan law?
Does anybody know for sure what DP's pan law is?
I suspect it's -3.5, but I have no way of confirming.
- FMiguelez
Re: DP pan law?
BTW, perhaps this is a clue?
In the Bounce to Disk dialog box, there's an option that reads "Mono with 3.5 dB attenuation".
But, shouldn't it be 6.02 dB attenuation if we don't take the pan law into account?
So, is that option with 3.5 dB attenuation ON TOP of DP's (automatic) pan law (so they add to 6.02 dB), or is it only a precaution to help avoiding clipping the signal?
I'm confused because, if I understand correctly, summing something to mono means the same signal will sound equally loud on both speakers, therefore duplicating the apparent loudness with respect to a hard panned signal.
That would be the same as increasing the voltage, or, in this case, the resulting gain by 6.02 dB, yes?
So why the 3.5 attenuation? Where does it come from?
Re: DP pan law?
There's power and amplitude.
https://en.wikipedia.org/wiki/Decibel
If you want to read a lengthy thread on the subject, try here. Logic, not DP but it will get you in the right direction.
https://discussions.apple.com/thread/1005954?tstart=0
Re: DP pan law?
-3.5 is what I've heard. I think I measured it once, but I don't remember the results.
Easy enough to figure out with a test tone. I think there are still some free test tone generators around. If not, there are plenty of tones as wav files on the interwebs.
Phil
Phil
Re: DP pan law?
I'm not sure what the pan law is in Texas, but I'm very careful to look all around for cops before I pan. If they don't catch me, I can pan any way I want.
Re: DP pan law?
Panacea or Pandemic?Shooshie wrote:I'm not sure what the pan law is in Texas, but I'm very careful to look all around for cops before I pan. If they don't catch me, I can pan any way I want.
PS: Hi Sooshie!
Re: DP pan law?
Exactly!HCMarkus wrote:Panacea or Pandemic?Shooshie wrote:
Re: DP pan law?
I fought the law and the pan won.
Re: DP pan law?
Pan puns...
Only at Motunation.
Only at Motunation.
Re: DP pan law?
(pandemonium)Babz wrote:I fought the law and the pan won.
- FMiguelez
Re: DP pan law?
You guys are making me panaroic with your jokes.
I haven't had time to test it (which is a good thing).
Re: DP pan law?
Lawst in Space.
Re: DP pan law?
Y'all are just fawning over this thread.
Re: DP pan law?
It's just our stereofawnics you are referring to.cuttime wrote:Y'all are just fawning over this thread.
Re: DP pan law?
It's 'cause yer back!Shooshie wrote:It's just our stereofawnics you are referring to.cuttime wrote:Y'all are just fawning over this thread.
Fawntastic.
