Changing lengths of soundbites upon import
When importing noninterleaved aifs from another project (by dragging in the "left" file) I often (not always) get two stereo files imported of differing lengths.
My hunch was that one was the original sound file and the other was a soundbite subset of that. But it seems to be more mysterious than this. If I trim the file in the audio editor (destructive), and then import it into a new project, the resulting audio file still imports into the new project as a few seconds longer.
Any ideas?
Any ideas?
Re: Changing lengths of soundbites upon import
Need more info. What kind of sound files?
Thank you, mikel. I'm sorry I was not more specific.
These are files that are found in the audio files folder of a DP project. They are not exported files. (If I go through the export process I don't have this issue).
what I do sometimes when moving files between projects, is to open the audio files folder and simply drag in the noninterleaved AIF Digital performer native audio file into a new project, avoiding any additional processing. Theoretically, this should be the "purest" way to do it.
I'm curious as to why it often will create two separate (stereo) imported files of differing length. ( this is not from mistakenly also dragging the right channel version. I only drag in the left.)
I use DP8.
I use DP8.
- buzzsmith
Mike knows much better than I, but I "think" that dragging the one audio file in also drags the "parent" or the "children" from previous edits even though only the one file was pulled in.
I've personally experienced this, as well.
Buzzy
Buzzy
Yamaha C7 Conservatory Grand
Hammond B-3 / Leslie 145
Focal Twin6 Be(s)
Focal Twin6 Be(s)
Yep. If you want the track without all the 'baggage' as it were, export it without conversion to another file type. This creates a copy. Otherwise, you're working with whatever you've done to the DP file in the new project.buzzsmith wrote:Mike knows much better than I, but I "think" that dragging the one audio file in also drags the "parent" or the "children" from previous edits even though only the one file was pulled in.
I've personally experienced this, as well...
I think you need to learn about Chunks. Plenty of threads and tutorials on this.
Your theory is flawed. If you want the original audio file, use the one you originally imported into the first project....what I do sometimes when moving files between projects, is to open the audio files folder and simply drag in the noninterleaved AIF Digital performer native audio file into a new project, avoiding any additional processing. Theoretically, this should be the "purest" way to do it.
You can also plan ahead. I do this with restoration and remix projects. I take the raw audio, clean it up using RX and/or DP till I get it as I like. Then I export those cleaned up but otherwise unedited files and store them in a folder—those are the files I use and edit in whatever forms the project will take.
If I need the original, raw files, they're always available to me. They are always kept in a folder I call Raw Audio so I'm never confused. This comes in especially handy recently when revisiting project with tools that weren't available the last time. Obviously, it saves your butt if you make an unwise decision involving destructive editing.
Thank you for the feedback.
I did go ahead and properly export the mixes to avoid issues.
It was my compulsive tendency to avoid any further processing and possible accidental dithering or any other unforeseen byproduct of the export process, that led me to try this. I know one can set export options. I was in fear of the unknown.
I just went to the extreme of "purity" thinking I'd just drag the mix directly out of the audio folder.
