Chunk Import
- supersonic
Chunk Import
When I slide another chunk into the active on everything gets copied but the FOLDERS are no longer assigned. Anyone found a solution to keep the them assigned to the tracks that were imported?
Music is movement in silence
- FMiguelez
Re: Chunk Import
That's the illogical way it currently is with DP, unfortunately.
Same thing happens with clippings. All tracks come out of their respective folders, for some unexplainable reason.
I've asked MOTU to fix this for years, to no avail
If you want this fixed, you should ALSO ask MOTU directly on the phone or via a Support Ticket, so they see more users need this to work as it's supposed to.
- supersonic
Re: Chunk Import
I did . It would also be nice to be able to import mix settings separately, pro tools style.
- FMiguelez
Re: Chunk Import
Nice!supersonic wrote:I did .
Hopefully more regulars, even if they are not that bothered by this, help us contact MOTU as well for more benign pressure.
How does this work in PT?supersonic wrote: It would also be nice to be able to import mix settings separately, pro tools style.
For instance, must you have a matching set of tracks to import "a mix" setting, or how does PT know where to put the plug-ins, etc?
What do those mix sets imports include?
Re: Chunk Import
Hello,
It's pretty elegant in PT. When you import a session you can choose what you want, automation, fades, time stamps, etc. It lists out the tracks to be imported and you can choose where to map them or create a new track. Works pretty good for SFX work and music collaborations. Of course now they want you to use the cloud instead.
It's the ear, not the gear!
