jumped to 5.1 Mac 2009, OS ?
Hey guys , just did the Firmware upgrade to 5.1 in my 2009 MacPro. Can I install Sierra at this time, thanks
2009 8 Core 5.1, 2012 6 Core MacPro,s , (32 gigs Ram) Mojave 14.6, Radeon 570, MacBookPros 2011, 2017 , 828MKIII Hybrid, 828X, MicroBook II, 8Pre, Nuendo 8ch A/D converter, PreSonus DigiMax LT ,DP11 , PT 2022.12, Cubase Elements 10.5, Peak 7, Logic 9 ,WaveLab 11, Reason 10, DSP-Quattro 5 ,many plugins , mics and synths. http://www.panaccimusic.com
- buzzsmith
If you're asking if it's possible, sure. Under the Apple in the Finder, select "Software Update". That should direct you to the App Store and there it is.
You might want to search this forum, though, to look at the recommended ways to do an OS update.
Backing things up, drive cloning, etc.
I'm sure some others with more expertise than I will chime in.
Buzzy
Buzzy
Yamaha C7 Conservatory Grand
Hammond B-3 / Leslie 145
Focal Twin6 Be(s)
Focal Twin6 Be(s)
Re: jumped to 5.1 Mac 2009, OS ?
Yeah , would like the best way to do that. Not sure so if someone can instruct that would be great, thanks !
+1 on possible. Working great for me on my 4.1>5,1.buzzsmith wrote:If you're asking if it's possible, sure...
Should be an easy update, but, always remember: Clone before you Moan (if it just happens to NOT work!) Also run Time Machine before updating.
HC Markus
Drive is backed up by Carbon Copy Cloner. Do I install over 10.9.5 or do I do a clean install first , thanks guys
Backed up to Time Machine is better. But, if your RAM is in tip-top shape, a clone should be ok. If you haven't booted from your clone and reinstalled 10.9.5, do so — this is how create a Repair Partition (download Mavericks from the App Store and reinstall).apanacci wrote:Drive is backed up by Carbon Copy Cloner. Do I install over 10.9.5 or do I do a clean install first , thanks guys
Now update to Sierra through the App Store.
If you have an issue (unlikely), use Migration Assistant to pull files from you clone—do not copy them over.
Some old plugs and apps might not like Sierra but all currently supported software does.
Worst case (highly unlikely) you would use your clone to re-clone to your system drive. Again, always re-install the OS onto any clone to create a Repair Partition.
Thanks Mike ! Why is Time Machine better ? Should I also bu with Time Machine on another free drive ?
