Why 24/192 downloads don't make sense. Great, Monty!
- FMiguelez
This guy Monty Montgomery wrote this great article about digial signal processing, modern converters and DAWs, etc.
There's also his related video, which is almost as good.
He explains everything beautifully, with SCIENCE.
I was never impressed with high SRs. I'm so glad I was never fooled by lying marketing departments and their crap.
But I do have some specal snake juice in case anyone is looking for some magic and hypersonic foolishness.
Great and nice light reading for a Sunday morning. And yes... I AM a proud geek
https://people.xiph.org/~xiphmont/demo/ ... tml#toc_lf
- terrybritton
- Primary DAW OS: Windows
Re: Why 24/192 downloads don't make sense. Great, Monty!
I've shared that article and video often - indeed great stuff!
I do still sell the "limited editions" of the virtual Brooklyn Bridge to anyone I can, though. A collector's item!
Terry
Terry
MOTU 828 mk3 hybrid
MOTU 828 mk3 hybrid
Hmmm... just how well is PonoMusic doing these days?
http://www.showbiz411.com/2016/11/04/ne ... er-outlets
- toodamnhip
I respect Neil for at least TRYING to improve music’s playback fidelity.mikehalloran wrote:Hmmm... just how well is PonoMusic doing these days?
Sigh
Mac Pro (Late 2013
2.7 GHz 12-Core Intel Xeon E5
64 GB 1866 MHz DDR3
Mojave
DP 10.13
MOTU 8pre, MTP AV, 828 mkII
64 GB 1866 MHz DDR3
Mojave
DP 10.13
Yes, this is a great article, in part because it gives references. One thing not addressed is the difference between 44.1 and 48, Many here have said they can hear the difference, me included. There were suggestions about confirmation biases, but also speculation that some converters are made to run at 48 and use some workaround to produce 44.1 files.
It depends very much on the individual converter implementation. The older PCIe MOTU line sound obviously cleaner/clearer in the top end at higher rates. The newer AVB line reveals less difference. Either one (and likely any converter out there) has more linear phase response as rates go up. At 44K1, it wouldn't take more than a couple converter round trips to have your top end 180 degrees out of phase with your bottom end.
Doug Williams
Tape Op issue 73
DP 11.31
Studio M1 Max OS12.7.3
MOTU 16A and Monitor 8
Tape Op issue 73
DP 11.31
There is one critical difference. Music for picture is required to be at 48k. That has nothing to do with fidelity or perceivable improvements in audio. It has everything to do with frame rate.bayswater wrote:Yes, this is a great article, in part because it gives references. One thing not addressed is the difference between 44.1 and 48...
For someone who writes a lot of music to picture it makes sense to stay at 48k and leave it there.
Set it and forget it. Can I hear a difference? I never spent the time to sit in a room quiet enough to judge that for myself. I know people with wa better hearing than I have and I wouldn't be the least bit surprised if some of them can, in fact, hear the difference. In my daily work (which does require I drop to 44.1k every so often) I can't hear a difference great enough to warrant one or the other.
The whole 44k thing dates back to CDs, which are all but obsolete at this point. Digital stuff is usually highly compressed and dumbed down, in one way or another. So 48k would seem overkill. Then again, the times they are always a-changin' and it wouldn't be surprising if the industry adopted 48k as the new standard. They may not, of course, but if they did, I like knowing my music is ready to go and conversions would be unnecessary.
So for the hobbyists, I'd say 44/1 is fine. You other guys might want to think about 48/24 as the standard.
Just sayin'...
Yes, using 48 is a no brainer. The file size difference is trivial and conversion to other rates is easy. So 48 is as good a standard as any.
But there was probably a reason for going to 48, and the article suggests it was a bogus reason. He says when it comes to playback, 16/44.1 is as good as anything.
- FMiguelez
After going back and forth between 44,1/24 and 48/24, I finally settled on the latter at 48.MIDI Life Crisis wrote: So for the hobbyists, I'd say 44/1 is fine. You other guys might want to think about 48/24 as the standard.
Mostly because of the convenience of dealing with music production houses, since 99% of what I do is broadcast anyway. This is despite my libraries being almost all at 44.1, so DP or VE Pro do the SRC in real time, with no discernible extra CPU hit.
44.1 and 48 sound the same to me so far with my libraries.
- FMiguelez
If you guys liked the article (I KNEW you would), here's his video about it>
Skip to 3:00 if you want to get down to it
https://www.youtube.com/watch?v=FG9jemV1T7I
And also this, of course. with Ethan Winer:
https://www.youtube.com/watch?v=BYTlN6wjcvQ&t=55s
Just to be clear, it was MLC that posted the statement under "bayswaster"FMiguelez wrote:After going back and forth between 44,1/24 and 48/24, I finally settled on the latter at 48.MIDI Life Crisis wrote:bayswater wrote: So for the hobbyists, I'd say 44/1 is fine. You other guys might want to think about 48/24 as the standard.
- FMiguelez
Sorry. It was my fault, Bays.bayswater wrote: Just to be clear, it was MLC that posted the statement under "bayswaster"
I'll edit my post.
