Which OS?
Which OS?
I have a mid 2010 5.1 Mac Pro with Mountain Lion. I want to update the OS. Is there any consensus on going with El Capitan, or is Sierra solid at this point?
Mac Pro 2x2.4 quad core /24 gb ram/OS 10.13.6, Dp 10.13, MTP AV, /UAD 2, KOMPLETE 12, Stylus RMX, SD 3.0, EZ Drummer 3, A&H ZED R 16.
Re: Which OS?
I've been contemplating the same.
Do you already have a copy of El Cap installer? Otherwise you're stuck to go to Sierra.
Sierra has SIP hidden, so need to use a terminal command to bring it back.
See here, thanks to Mike H:
viewtopic.php?f=4&t=63217&start=15
Re: Which OS?
I do have an El Cap installer. But I'm also thinking why not just install Sierra now, to save having to do another OS install in 6 to 8 months. What is SIP? Probably not "Solo In Place".
Re: Which OS?
I moved from ML to Sierra and, except for the 9.1x MIDI cc64 punch in bug (which does not appear to be os related) all is well. Sierra is cool if you want to use a more current GPU and drive a 4K monitor.
HC Markus
Re: Which OS?
SIP= system integrity protection - you cannot install non app store or Apple signed app's without disabling the feature in OS X.
Mike provided the terminal command ( see the link in my previous post) to un hide SIP in Sierra.
Re: Which OS?
You are confusing SIP with Gatekeeper, part of the OS since Lion but now hidden in Sierra.Tonio wrote:SIP= system integrity protection - you cannot install non app store or Apple signed app's without disabling the feature in OS X.
SIP is enabled by default in El Cap and Sierra. Apps are now brickwalled from the Root (and should have been since Lion but not all developers believed that Apple meant it). To disable, one must Option-Boot into the Recovery partition and run certain commands.
Anyway, certain old applications and installers will not work properly if SIP is enabled and this caused a lot of grief a couple of years ago. If SIP is not an issue, leave it alone — there are many old threads if it causes problems and I do have the terminal commands archived.
It's safe to say that all supported apps have released drivers and updates that comply with the Apple Toolkit now (old ones can be a different issue). If you are on Yosemite and everything is working well, you are unlikely to have issues involving SIP when you upgrade (Soundflower may be an exception and there are versions that no longer write to the Root).
Disabling Gatekeeper will allow DP 7.24 to be installed up to El Cap. Nothing will make that installer work in Sierra including disabling SIP.
Re: Which OS?
I skip every other OSX release. Just recently upgraded to Sierra from Yosemite. No issues so far.
El Crapitan (spelling intentional) was in between Yosemite and Sierra. Apple has long had a habit of releasing screwed-up OSX versions which are always followed by another version that "fixes" the previous lame version.
Example - Leopard (bad)>Snow Leopard (great) Lion (bad)>Mountain Lion (great) Mavericks (bad)> Yosemite (great)>El Crap (bad)> Sierra (great - so far).
You can't get El Crap from the App Store anymore anyway. I suggest moving up to Sierra. But yes, you really do need to upgrade your version of DP.
Never even knew SIP existed, don't care since I don't use many apps on my Mac Pro. To get around Gatekeeper without diving into the Terminal, download and install Mountain Tweaks. It was made for Mountain Lion but works fine in Sierra, and it disables gatekeeper as well as other "convenient" features like disappearing scrollbars - donationware:
http://tweaksapp.com/app/mountain-tweaks/
http://www.davepolich.com
- buzzsmith
Re: Which OS?
Following, as I'm really close to going to Sierra-Land. (From 10.8.5)
Making my application list and checking which (primarily non-audio) apps, etc. might need updating.
Buzzy
Buzzy
Yamaha C7 Conservatory Grand
Hammond B-3 / Leslie 145
Focal Twin6 Be(s)
Focal Twin6 Be(s)
Re: Which OS?
I say go for it. I just updated my wife's Mac from Mountain Lion to Sierra and she had a bunch of vintage clerical software on it including Office 2011 and Acrobat Pro 8. I was dreading it, but it turned out to be very painless. After the update her Mac even decided her printer and scanner drivers needed an update, too. All is well.buzzsmith wrote:Following, as I'm really close to going to Sierra-Land. (From 10.8.5)
Buzzy
Re: Which OS?
[quote]I skip every other OSX release. Just recently upgraded to Sierra from Yosemite. [/quote]
Yeah, I've been strictly 10.4→10.6→10.8→10.10. I never even used the odd numbers. I just went from 10.8.5 to 10.10.5. I can't say I'm thrilled with it, but after many days of sorting things out it's working well enough to not make me go back. For now.
I always just buy a new set of drives when I upgrade and leave my old system and one backup just like it was. Clone it over and start from there.
My disappointment with Apple is that every new OS breaks compatibility with older stuff I like, which is understandable, but as time goes on each one brings me less positives. Tags is really the only thing I like about 10.10, and that wasn't worth switching for. Compatibility with new releases is the only real plus. Losing old software sort of balances it out though.
Re: Which OS?
Yea, Acrobat 8 will no longer install but if it's already installed, it will work when you upgrade the OS. Office 2008 is the same way. Office 2011 and Acrobat Pro can still be installed in Sierra — you may have to disable Gatekeeper but that's easy as I've mentioned.cuttime wrote:...I say go for it. I just updated my wife's Mac from Mountain Lion to Sierra and she had a bunch of vintage clerical software on it including Office 2011 and Acrobat Pro 8. I was dreading it, but it turned out to be very painless. After the update her Mac even decided her printer and scanner drivers needed an update, too. All is well.
Re: Which OS?
If DP 7.24 is already installed on an i5 machine running OSX10.7.5 is this version of DP likely to keep running if the OS is upgraded directly to Sierra?mikehalloran wrote: Disabling Gatekeeper will allow DP 7.24 to be installed up to El Cap. Nothing will make that installer work in Sierra including disabling SIP.
DP10.13, OSX 10.13.6, Melodyne Studio 4.1, Dorico Pro 3.5, Sibelius 7.1.3, MOTU Mosaic 1.5, MOTU Traveler mk1.
Re: Which OS?
I wish I could help, but I really just wanted to say that it's nice to see you back here, Nigel. If you don't recognize "Tritonemusic", I used to go by "666" in the old days.Nigel Keay wrote:If DP 7.24 is already installed on an i5 machine running OSX10.7.5 is this version of DP likely to keep running if the OS is upgraded directly to Sierra?mikehalloran wrote: Disabling Gatekeeper will allow DP 7.24 to be installed up to El Cap. Nothing will make that installer work in Sierra including disabling SIP.
Sorry for going OT.
Re: Which OS?
Yes, it will still run—at least my copy does. I keep it in case I have to revisit some old projects. They will open on 9 but not all the plugins do. Sometimes, it's easier to analyze them and replace ancient plugs in 7.24 than open in 9 and guess how the heck I did (fill in the blank).Nigel Keay wrote:If DP 7.24 is already installed on an i5 machine running OSX10.7.5 is this version of DP likely to keep running if the OS is upgraded directly to Sierra?mikehalloran wrote: Disabling Gatekeeper will allow DP 7.24 to be installed up to El Cap. Nothing will make that installer work in Sierra including disabling SIP.
I don't know that, if you had a system crash, a Time Machine restore would work to restore 7.24 but it might as long as you have access to a CD drive to Authorize the license. I think it should but, till something happens, I'm not going to know for certain.
A fresh install of DP 7 cannot be done in Sierra. I tested that to satisfy my curiosity.
Re: Which OS?
Thanks for the welcome back "666", it's true I haven't posted much recently, but have been dropping in to read what's goin' on.
Thanks mikehalloran for that info. I got Dorico recently then realised it needs Mavericks or later to run, so I think I've almost got the courage to update to Sierra. I also want to keep Sibelius 7.1.3 running, and from what I've read that'll work too.
Even Adobe CS5 seems to work on Sierra (we already have Sierra on another machine). After a quick glance at CS5 Bridge, which I like using to put metadata on audio files created by DP, the itunes icon shows on .wav and .mp3 inside Bridge and doesn't allow the file to be modified. PDF and jpeg files allow the tagging. I assume Bridge basically works but there's something controlled by itunes that prevents tagging the audio files.
