Digital Performer 9.1.3 Read Me
Thank you for installing Digital Performer 9.1.3.
Complete DP9 documentation
You can find complete DP9 documentation (PDF files) on the DP9 installer disc, and you can also access them directly from Digital Performer's Help menu. Table of Contents entries, index entries, and cross references are live links that will jump to their destinations. In some cases, you may need to click directly on the page number (rather than the heading).
Changes and new features
For a comprehensive list of new features, please refer to New Features in DP, available in Digital Performer's Help menu.
Enhancements introduced in version 9.1.3
Version 9.1.3 provides improvements, optimizations, and refinements. Here are just a few highlights:
• Improved Hardware Insert plug-in latency detection. Added level meters and fixed a bug when pasting settings.
• Allow more than 32,000 MIDI tracks in a project.
• Improved support for Softube when tracks are reordered.
• Improved support for Melodyne.
• Improved latency compensation for VST2 plug-ins.
• Improved support for VEP and virtual instruments that have variable latency.
• Improved support for the RME Fireface driver.
• Fixed a bug where certain plugins (MX4, for example) would not get numbers appended to side-chain bus names.
• Fixed a bug where erasing a selection containing soundbites with fades would sometimes cause a click.
• Fixed a bug where editing the head of a soundbite with a fade on it’s tail would sometimes cause a click.
• Fixed an issue where chased MIDI events would not update faders and other graphical indicators.
• Fixed a bug where the main counter format was not being restored when opening a file in some cases.
• Fixed a bug where Wave files with time-stamps of > 0x7FFFFFFF would not spot correctly.
• Fixed an issue where pasting at an insertion point in a pop-edited soundbite would not place the data at the correct location.
• Fixed a bug where deleting chunks with the track selector showing could cause a crash.
• Fixed some popup menu behavior.
• Fixed a bug that could lead to a crash when edge-editing MIDI notes following the deletion of pitch bend data.
• Fixed an issue where using the scale tool on soundbite volume would not update playback such that the modification could be heard.
• Fixed a crash that could occur when closing various editor windows.
• Fixed an issue with recalling Mixing Board layouts.
• Improved mouse tracking when editing pitch bars.
• Fixed an issue where including Film Scoring Events in a movie bounce could cause frame rate irregularities.
• Fixed an issue with code signing the Windows installer.
Enhancements introduced in version 9.1.2
Version 9.1.2 provides many improvements, optimizations, and refinements. Here are just a few highlights:
• Fixed a bounce to disk crash caused by an issue involving non-active VST effects.
• Fixed a problem where audio would sound choppy after inserting a post-fader effect. • Fixed a crash that could occur if a clipping window was closed while one of its clippings was being auditioned.
• Fixed a crash involving Melodyne.
• Fixed an issue where project VIs would not work correctly when selected as MIDI metronome.
• Optimized code that could impact opening projects with a large number of tracks.
• Fixed an issue where the Ivory Synthogy would hesitate and glitch when beginning playback in pre-gen mode.
• Fixed an issue where recording MIDI data into a track with sustain CC could clear the live state of the sustain pedal.
• Fixed an issue where overdubbing notes in a MIDI track would halt sounding notes already on that track.
• Fixed a case where track sysex data could cause a crash during playback.
