Hey folks,
Curious about this selection in the "Load..." menu. I've tried it a few times and it doesn't seem to do anything, but maybe I am just using it wrong. Anyone ever use "Load...Effect Settings"?
Mike
What does "Load...Effect Settings" do?
- Primary DAW OS: Windows
DP 10 - Win 10 - Ultralite AVB
Re: What does "Load...Effect Settings" do?
You can save you changes to effects (and name them) so that you can call them up later. You can also save entire plug-in sets in the living bard and load a particular group of presets in the same manner. in general, the LOAD command is different. That allows youth import a individual sequence from another project.
Thanks for the response - I'm aware of the general usage of the "Load" command, but one of the options on the dialog (along with consoles, soundbites, etc) is "effect settings". But the manual gives no details and as far as I can tell it doesn't do anything at all.
It probably applies to the MIXER. Save a mixer set (as described above) and see if you get the option of loading that.
A good idea, but I tried it and mixes appear to be included in the load operation with or without using the "Effect Settings" option.
