Going straight from working a track in the mixer window to
zandurian
Post by zandurian »
I find myself working on a track in the mixer window and then needing to jump directly to that same track in the tracks window (and vice versa) and it seems like I figured out how to do that once but forgot. Suggestions?
Mac Pro (early 2009 - originally 4,1 - flashed to 5,1) 2 x 3.42 GHz 6-Core Xeon X5690, 64 gigs PC3-10600 RAM, OS 10.13.3, DP9.52, UAD2 duo, UAD2 solo,
Superior drummer 2, Mach 5-3, Ivory, PCIe 424, BL modded 24i/o, MIDI express XT, unisyn, Melodyne 2, Izotope RX2, Addictive Drums, Pianoteq
mesayre
Re: Going straight from working a track in the mixer window
Post by mesayre »
I use the Channel Strip window for this. If you only need access to that one track at a time, it's just the ticket. (Studio->Channel Strip in DP8, though I'm not sure if it moved to a different menu in DP 9)
I'm not sure if there's another way to open it up in full mixer, though.
zandurian
Post by zandurian »
mesayre wrote:I use the Channel Strip window for this. If you only need access to that one track at a time, it's just the ticket. (Studio->Channel Strip in DP8, though I'm not sure if it moved to a different menu in DP 9)
Thanks for this info. :idea:
That's great. Forgot about that.
