Memory Cycle & Overdub On, record goes off after first pass
stevenew
Post by stevenew »
I think I am going mad...
For the first time since going over to DP9 I have set up a project to start writing a new piece. I have Memory Cycle and Overdub on, I hit record but after the first pass record goes off. It only seems to be in this project, if I create a new one it works as expected and record stays on.
What have I done? I am sure I had this once before in DP8 but I cannot remember what I did.
I have tried trashing the DP preferences file but still the same with this project.
2018 3.2 GHz 6-Core Intel Core i7 16GB. External SSD Sample Drives. macOS Monterey 12.2. MOTU 624 & 8D. Cubase Pro 11, Wavelab Pro 11, DP 9.52, DSP Quattro 5. Arturia, Gforce, iZotope, NI, Plugin Alliance, Slate, SSD5, Soniccouture, Spectrasonics, Spitfire. Novation 61 SLMKII, JBL LSR 305, Sennheiser HD600, AKG 240MKII. PRS, Martin Guitars, Mensinger Bass. Vox & Orange amps. Line 6 Helix.
FMiguelez
Re: Memory Cycle & Overdub On, record goes off after first p
Post by FMiguelez »
Could it be that auto-record (punch-in) is engaged? Check that, since it's easy to miss when various transport modes are on.
The shortcuts are a couple of the function keys, F5 or F6.
stevenew
Post by stevenew »
FMiguelez wrote:Could it be that auto-record (punch-in) is engaged? Check that, since it's easy to miss when various transport modes are on.
That was one of my thoughts, but no:
Edit: Oops, for some reason image not showing! Really not my day today:-)
OK so now its showing - I really am losing it:-)
Phil O
Post by Phil O »
Sometimes a project file gets corrupted. That might (or might not) be the case here, but it is highly suspicious seeing that the problem only shows up in one of your projects. I'd try loading the sequence into a new project and see if it solves the problem. It won't give you the satisfaction of knowing what went wrong, but at least maybe you can get your work done.
Phil
stevenew
Post by stevenew »
Phil O wrote:Sometimes a project file gets corrupted. That might (or might not) be the case here, but it is highly suspicious seeing that the problem only shows up in one of your projects. I'd try loading the sequence into a new project and see if it solves the problem. It won't give you the satisfaction of knowing what went wrong, but at least maybe you can get your work done.
Phil
Good point Phil, I will try loading the sequence into a new project later. Whenever something like this happens I am always convinced I have done some unintentional key combination.
stevenew
Post by stevenew »
Loading the sequence into a new project works fine, so I guess the original project is corrupted:-( Wish I knew what I did.
A little worrying as it was my first new project with DP 9.02 and Sierra 10.12.3.
