Load... VRack? [RESOLVED]
- SMS
Is there any way to import a VRack from one project to another?
Load... doesn't seem to accommodate that...
MOTU user since Performer™ 1.22 on 128k floppy
DP 11.23
MacBook Pro 14” 2023 M2 max 12 core
64 Gb RAM
4TB SSD
OS 14.0 Sonoma
UAD Apollo 8
828 mk3 Hybrid
MIDI Express XT
DP 11.23
64 Gb RAM
4TB SSD
OS 14.0 Sonoma
UAD Apollo 8
828 mk3 Hybrid
MIDI Express XT
Re: Load... VRack?
In your mixer at the top of the channel there's a dropdown that let's you "save inserts." That should do it. Save and load from there. You might also have to create multis for the VIs as I am not sure it will save those but I suspect it will.
Re: Load... VRack?
And maybe not... I just tried it and cannot open any inserts...
Re: Load... VRack?
But that is supposed to work...
- FMiguelez
Re: Load... VRack?
That's strange... I use the Load command to import regular sequences and VRacks all the time, and it works perfectly.SMS wrote:Is there any way to import a VRack from one project to another?
When you call the Load command, it should list every sequence and VRack that the sequence contains.
Are you sure there are VRacks in the project you're trying to import?
- terrybritton
- Primary DAW OS: Windows
Re: Load... VRack?
I'm a little lost here. When you load a project file that used VRacks, it shows in the "Load Chunks" window all the available chunks AND VRacks. You select them (Command/CTRL click to select several) and hit OK. Done!SMS wrote:Is there any way to import a VRack from one project to another?
Are you describing something different? [Edit - I see FMiguelez and I posted at the same time!]
Terry
MOTU 828 mk3 hybrid
MOTU 828 mk3 hybrid
- SMS
Re: Load... VRack?
Doh. I forgot it's just another chunk
DP 11.23
64 Gb RAM
4TB SSD
OS 14.0 Sonoma
UAD Apollo 8
828 mk3 Hybrid
MIDI Express XT
DP 11.23
64 Gb RAM
4TB SSD
OS 14.0 Sonoma
UAD Apollo 8
828 mk3 Hybrid
MIDI Express XT
- terrybritton
Re: Load... VRack?
AND one of the coolest things about DP!SMS wrote:Doh. I forgot it's just another chunk
Glad you have it sorted!
Terry
MOTU 828 mk3 hybrid
MOTU 828 mk3 hybrid
Re: Load... VRack?
Right right right right right.... as the English say. It's a bloody chunk in and of itself.
Bloody chunk... now there's an image for ya!
