Preroll for markers ?
Klaus
Post by Klaus »
Is there a way to set a preroll for markers ?
i.e. I'm setting markers on the fly, and when jumping to these, preroll is engaged ?
DP 7.24 :oops:
TIA
Klaus
Re: Preroll for markers ?
I could see how that would be useful.
As a workaround, you could click to go to the marker then use a key command to nudge the wiper back in whole measure increments.
I suppose you could also copy all your markers--- lock all the copies then choose shift locked markers. The only hitch with this is that measures|beats|ticks isn't a format you can use in the shift amount. You'd have to first look at how long a measure (or two, or whatever) is.
Hope that helps.
Klaus
Post by Klaus »
Thanks stubbsonic !
Best regards
Klaus
