Blank tracks to clippings window [RESOLVED]
- philbrown
Say I want to take a whole drum kit worth of blank tracks with all I/O set up, plugs, auxes in place and make a clipping out of that to drag into another file. It seems like an obvious function for clippings but I can't figure out how to do it.
TIA, (also my dog's name)
Phil
Phil
Re: Blank tracks to clippings window
You can save the INSERT SETTINGS from the mixer channel, for one, and call those up in any sequence/chunk. Otherwise yo might have to insert a bit of data to make the "blank" tracks into clippings. Maybe a cc#7 at 127, since that will usually be the default anyway.
- philbrown
Thanks, MLC. This would be audio tracks.MIDI Life Crisis wrote:Otherwise yo might have to insert a bit of data to make the "blank" tracks into clippings. Maybe a cc#7 at 127, since that will usually be the default anyway.
Blank audio? Again, I think the best way is to add a little data and save the channel settings in the mixer dropdown. Is that not working?
- philbrown
I'll have to try it.MIDI Life Crisis wrote:Blank audio? Again, I think the best way is to add a little data and save the channel settings in the mixer dropdown. Is that not working?
Well what are you waiting for?
j/k man, but it should work. Then there are always templates, which you can LOAD from. THere's many way to kill this squirrel.
- philbrown
LOL I know but I'm tracking my lovely 12 string guitar at the moment.MIDI Life Crisis wrote:Well what are you waiting for?
- philbrown
Seriously - look a squirrel
philbrown wrote:Seriously - look a squirrel
- philbrown
Yeah, I do that all the time. Unfortunately I'm pretty sure that's strictly one track at a time. Better than nothing but inconvenient for lots of plugs on multiple tracks.MIDI Life Crisis wrote:You can save the INSERT SETTINGS from the mixer channel, for one, and call those up in any sequence/chunk.
OK, I think I finally did things in the right order.MIDI Life Crisis wrote:Otherwise yo might have to insert a bit of data to make the "blank" tracks into clippings. Maybe a cc#7 at 127, since that will usually be the default anyway.
1. I created a DP Clipping window
2. Drum tracks were already grouped so I just time selected the first bar (from a whole song)
3. Edit menu > Copy to clipping window
4. Open destination file and drag clipping to left side of Tracks Overview or Sequence editor
5. Select the resulting measure of 'dummy data' and delete
Viola! I mean drum tracks! With all plugs in place! Yay!
The only thing that didn't come over was the track group but that's trivial compared with all the routing, formatting and ALL PLUGS AT ONCE!
Thanks very much MLC!
The 'bit of data in the track' was what I was missing before.
Re: Blank tracks to clippings window [RESOLVED]
I so want to take credit for all of MOTUs hard work. But alas, it's just a damn great program and company. Glad you got it working.
