Strip data but leave plug-ins?
- philbrown
Here's my example:
We tracked a song and I worked some on the drum mix but then we decided to re-track at a different tempo.
I want to:
1. Remove all soundbites, MIDI and automation from all tracks *including underlying takes*
2. Leave the (now blank) tracks in place
3. Leave all I/O settings in place
4. Leave all plugs in place
I tried 'Duplicate Track Layout' in the chunks mini-menu but it deletes all the plugs.
I want to:
Re: Strip data but leave plug-ins?
Duplicate Mix would keep the plugins. Replace Soundbites would do what it says. But you'd have to manually delete the automation.
- philbrown
Thanks. Took me a while to find these.bayswater wrote:Duplicate Mix would keep the plugins. Replace Soundbites would do what it says. But you'd have to manually delete the automation.
Duplicate Mix - didn't delete any data at all.
Replace Soundbites - doesn't seem to do anything. According to the manual that's to replace all instances of a SB with a different one.
- buzzsmith
Okay,I just tried this...
In the Sequence Editor, ONLY show the drum tracks.
Use Command-a to select all tracks.
While highlighted, press Delete.
All is gone, mixer is unaffected.
Hope that helps!
Buzzy
Hope that helps!
Buzzy
Yamaha C7 Conservatory Grand
Hammond B-3 / Leslie 145
Focal Twin6 Be(s)
Focal Twin6 Be(s)
- philbrown
Thanks Buzz - that's what I'm already doing basically. Not sure what the significance is of 'ONLY show drum tracks' is but I did try exactly what you said (I think)– but that doesn't get rid of the underlying takes, which is the most time-consuming part of what I'm trying to do.buzzsmith wrote:Okay,I just tried this...
Hope that helps!
Buzzy
- buzzsmith
Wow.philbrown wrote:Thanks Buzz - that's what I'm already doing basically. Not sure what the significance is of 'ONLY show drum tracks' is but I did try exactly what you said (I think)– but that doesn't get rid of the underlying takes, which is the most time-consuming part of what I'm trying to do.buzzsmith wrote:Okay,I just tried this...
Hope that helps!
Buzzy
I just tried it again with a vocal track that also has soundbites "under" the primary vocal.
When highlighted (by selecting Command-a with this being the only track visible) and pressing delete, everything is deleted including the underlying snippets.
And the reason for only showing the drum tracks, in your case, is to only affect the tracks you wanna delete info from. If you also had a bass and a guitar, for instance, visible the Select All command would also affect those 2 tracks.
Buzzy
Focal Twin6 Be(s)
Focal Twin6 Be(s)
- philbrown
Thanks Buzz! Honestly I'm reading your post word for word and doing that and it's not deleting anything from underlying takes.buzzsmith wrote:Wow.philbrown wrote:Thanks Buzz - that's what I'm already doing basically. Not sure what the significance is of 'ONLY show drum tracks' is but I did try exactly what you said (I think)– but that doesn't get rid of the underlying takes, which is the most time-consuming part of what I'm trying to do.buzzsmith wrote:Okay,I just tried this...
Hope that helps!
Buzzy
Buzzy
- buzzsmith
I'm quite sure!philbrown wrote: Thanks Buzz! Honestly I'm reading your post word for word and doing that and it's not deleting anything from underlying takes.
Just to be clear...we're not talking about a Take 1, Take 2, etc. are we?
When you actually designate a Take 1 or 2, etc. for each drum track?
Focal Twin6 Be(s)
Focal Twin6 Be(s)
- philbrown
Not separate takes as tracks but underlying takes.
you might try this.
Select all the tracks in track overview window. Temporary group them (double tap t key)
In the tracks group mini menu, check that the takes options are checked. (delete take, switch, rename take, etc)
In tracks overview, go to the takes column and select "delete all except (current take)"
Now all tracks should only have the 1 visible take.
Hit command A to select all
Hit Delete (deletes the remaining soundbites, automation)
You can rename the take in take column "1" and all the grouped tracks will change.
Carlos
Carlos
- philbrown
Thank you very much, Carlos.csavetman wrote:you might try this.
Carlos
- buzzsmith
Oops. Late to the party!
Just to prove to you (and I) that I'm not imagining things here are 3 screenshots of how I do it.
1. Tracks showing soundbites underneath and random automation...
2. Tracks highlighted after selecting all...
3. After using the delete key...
Whatever works!
Buzzy
Whatever works!
Buzzy
Focal Twin6 Be(s)
Focal Twin6 Be(s)
- philbrown
Buzz, I swear* I did exactly that and it didn't delete the underlying takes.
*98%
*98%
If I'm not mistaken, I think Phil is referring to additional takes as in the take dropdown menu. Highlighting the tracks as per your example, wouldn't delete takes 2 thru ...if there were any additional takes.buzzsmith wrote:Oops. Late to the party!
Whatever works!
Buzzy
At least that's what I think he meant.
Carlos
- philbrown
Exactly.csavetman wrote: If I'm not mistaken, I think Phil is referring to additional takes as in the take dropdown menu. Highlighting the tracks as per your example, wouldn't delete takes 2 thru ...if there were any additional takes.
Carlos
