Automation in OMF file
apanacci
Post by apanacci »
Hey guys, I was looking at the Avid forum and someone had posted saying that an OMF file from DP opened in PT has automation. Where do you choose that in the export ?
2009 8 Core 5.1, 2012 6 Core MacPro,s , (32 gigs Ram) Mojave 14.6, Radeon 570, MacBookPros 2011, 2017 , 828MKIII Hybrid, 828X, MicroBook II, 8Pre, Nuendo 8ch A/D converter, PreSonus DigiMax LT ,DP11 , PT 2022.12, Cubase Elements 10.5, Peak 7, Logic 9 ,WaveLab 11, Reason 10, DSP-Quattro 5 ,many plugins , mics and synths. http://www.panaccimusic.com
Morpheo
Re: Automation in OMF file
Post by Morpheo »
Maybe that was my post over at the DUC... I was referring to AAFs - make sure you check "export clip-based volume" and the automation will show up in Pro Tools (although "clip-based volume" does sound different than "volume automation", more like "clip gain", but otherwise automation is not exported). Also don't check "interleaved" for the audio files, or DP will mess things up and export them in mono (!!)...
Mac Pro 5,1 12-core 2.4 GHz//40GB RAM//RX 560//macOS 10.13.6//SSDs//MOTU 896//Keylab 88//Faderport 8
Pro Tools 2018.7//LPX 10.4.1//DP 9.51
NI Komplete Ultimate 11//Albion One//Soundiron Choirs//Pianoteq//Analog Lab//VSL SE & Chamber Strings//etc
