Markers window always on top?
Is there a way to alway keep the markers window on top?
waxman
- buzzsmith
Re: Markers window always on top?
Not positive, waxman. I usually just move it to the top right of my display where I can get to it easily...or to my second display which is far less cluttered.waxman wrote:Is there a way to alway keep the markers window on top?
Buzzy
Yamaha C7 Conservatory Grand
Hammond B-3 / Leslie 145
Focal Twin6 Be(s)
Focal Twin6 Be(s)
I park it in the right side bar of the Consolidated window but I have a window set for film spotting that has it popped out large size on my second monitor.
Frank Ferrucci
http://www.ferruccimusic.com
Thank you... I only use the sends and inserts on the mixer but when I bank 24 channels on the Raven the mixer covers it up... pia... I do to the top right corner also. I can't find a safe place to put it... wish it would float...
waxman
- buzzsmith
I'm sure you know (but I'll mention it anyway!) that Shift-k brings it to the front.
Didn't know you had the Raven.
Buzzy
Buzzy
Focal Twin6 Be(s)
Focal Twin6 Be(s)
Wow... it never ceases to amaze me... for 20 years I've always had the marker window in a side window to the TO... Now my DP mixer sits above the Raven floating mixer and Batch commander racks. Everything is very fluid. Much of the time it's what I want but when I need to see the markers invariably Murphy shows up and the Markers window is partly hidden in the top right corner by the DP mixer... Then Buzzy says hey "shift K"buzzsmith wrote:I'm sure you know (but I'll mention it anyway!) that Shift-k brings it to the front.
Buzzy
Well no Buzzy I didn't know that and it's people like you that make M-Nation awesome. Thanks so much my friend.
Yes been a Raven user for 13 months. Love it... game changer, revolutionary, critical, disrupting, most awesome piece of gear ever developed... Just call me the Slate Fan Boy... hahaha
waxman
I have the same problem with the Automation Setup window, I wish it would float.. but you can't even put it in the CW like you can the markers, etc.
- buzzsmith
You're quite welcome!waxman wrote: Wow... it never ceases to amaze me... for 20 years I've always had the marker window in a side window to the TO... Now my DP mixer sits above the Raven floating mixer and Batch commander racks. Everything is very fluid. Much of the time it's what I want but when I need to see the markers invariably Murphy shows up and the Markers window is partly hidden in the top right corner by the DP mixer... Then Buzzy says hey "shift K"
I, too, learn so much from fellow users here on this great forum.
Buzzy
Focal Twin6 Be(s)
Focal Twin6 Be(s)
I use a work around and have the channel strip just with the automation in the top left hand corner of the Raven... You can bring it up with short cut ( opt shift command cntrl ; )Killahurts wrote:I have the same problem with the Automation Setup window, I wish it would float.. but you can't even put it in the CW like you can the markers, etc.
then I have the Markers on the top right hand with the DP mixer only inserts and sends chosen in the middle. Works great. When I want to put a channel in automation I have a batch command button that does that. Select channel. Push button bingo automation record. I wish DP would decouple the automation row from the m/s/r buttons.
waxman
SAY what ?? Can you show us some picts. Or even a little video Wax? I can't envision it.waxman wrote:I use a work around and have the channel strip just with the automation in the top left hand corner of the Raven... You can bring it up with short cut ( opt shift command cntrl ; )Killahurts wrote:I have the same problem with the Automation Setup window, I wish it would float.. but you can't even put it in the CW like you can the markers, etc.
One picture is worth a 1000 words....Sorry quick iPhone pics but it should give you the idea...labman wrote:SAY what ?? Can you show us some picts. Or even a little video Wax? I can't envision it.waxman wrote:I use a work around and have the channel strip just with the automation in the top left hand corner of the Raven... You can bring it up with short cut ( opt shift command cntrl ; )Killahurts wrote:I have the same problem with the Automation Setup window, I wish it would float.. but you can't even put it in the CW like you can the markers, etc.
set up
Top left hand corner
Buttons for turning on and off automation (green and red buttons "Automation Automation Record"
Overview
waxman
Thats a big help Wax. Very appreciated. I have my remotes and icons built, so this a next step I suppose.
Cool man... the channel strip thing for automation gives you back some vertical real estate on your monitor. I could not find keyboard short cuts for automation on and off. So I had to set up the batch command as a mouse move and click So I set up the channel strip to always be in the top left hand corner. If you figure out how to get keyboard short cuts for automation on off let me know...
waxman
That is one of things I was stumped on. Have you asked Jamey?waxman wrote: If you figure out how to get keyboard short cuts for automation on off let me know...
Hey Labman... Actually it was a rhetorical question.... There are no key short cuts built into DP for automation. That's why I came up with the Batch Command on the channel strip which is always anchored in the top left and corner of my Raven monitor. It allows me to use mouse commands to access the dp automation. I can arm and disarm the automation from with those batch command buttons in the pics I posted. Those BC's contain mouse commands. The plus side is I don't lose vertical real estate having to use the DP automation which is anchored in with the mute/record/solo buttons in the dp mixer. That takes to much vertical space on the monitor. Do you know how to make those batch commands? if not I can post it on the Slate forum.labman wrote:That is one of things I was stumped on. Have you asked Jamey?waxman wrote: If you figure out how to get keyboard short cuts for automation on off let me know...
waxman
