Latency DP8 -DP9
apanacci
Latency DP8 -DP9
Post by apanacci »
Hey guys, one more question about DP9. I am running FW on a 828 MKIII Hybrid. I am running DP8. In the specs of DP 9 MOTU says there is a difference in latency using a Thunderbolt connection audio interface. Will I notice a difference with the FW hookup in DP9, thanks !
2009 8 Core 5.1, 2012 6 Core MacPro,s , (32 gigs Ram) Mojave 14.6, Radeon 570, MacBookPros 2011, 2017 , 828MKIII Hybrid, 828X, MicroBook II, 8Pre, Nuendo 8ch A/D converter, PreSonus DigiMax LT ,DP11 , PT 2022.12, Cubase Elements 10.5, Peak 7, Logic 9 ,WaveLab 11, Reason 10, DSP-Quattro 5 ,many plugins , mics and synths. http://www.panaccimusic.com
artfarm1
Re: Latency DP8 -DP9
Post by artfarm1 »
I'm using FW as well, with a Traveler mkI that's still working like new.
I like playing MIDI instruments in DP 9.02 or 9.12. There might be less latency,.... it's better....it's subliminal...we're talking micro-milliseconds I believe....but MIDI response does seem excellent in DP9.
DP 11, OS Ventura
MacMini 2023 M2Pro, 16 gig RAM, MOTU M6, SSD drives for everything, various sound/sampled libraries from all major vendors, Logic Pro X, DSP-Quattro
MacBook Pro 2015, OSX Monterey, 2.5ghz, 16 gig RAM (w/duplicate software as in MacMini setup)
Trombones: King 2B SilverSonic, King 2B Liberty, & Conn 88H w/Doug Elliott mouthpieces!
http://www.cammillarmusic.com
Gravity Jim
Post by Gravity Jim »
DP9 displays about half the latency at the same buffer setting as does DP8. Well worth it.
Jim Bordner
Robert Randolph
Post by Robert Randolph »
I did some investigation myself, you can find data here: http://admiralbumblebee.com/music/2016/ ... -Test.html
Klaus
Post by Klaus »
The latency increase happened way before DP 9…
DP3 or 4 was ok :D
Best
Klaus
