DP MIDI track base vs clip base question
In order to balance my orchestral template, i want to insert at the beginning of my MIDI tracks CC1, CC7 and CC11. I'm so used to doing it the cubase/PT's way where MIDI is clip base. I simply insert a 1 bar clip and enter the needed CC values.
What's the best way to achieve this in DP ? Thx
Re: DP MIDI track base vs clip base question
Give snapshots a try
Frank Ferrucci
http://www.ferruccimusic.com
I use a global clipping. Here's how (from scratch):vudoo wrote:In order to balance my orchestral template, i want to insert at the beginning of my MIDI tracks CC1, CC7 and CC11. I'm so used to doing it the cubase/PT's way where MIDI is clip base. I simply insert a 1 bar clip and enter the needed CC values.
Create your initialization sequence in a MIDI track.
Use Project->Clippings->New Digital Performer Clipping Window (if you haven't already). Call it something you'll recognize later (i.e. Global Clips). This creates a clipping window you can use in any project.
Now select the MIDI events, and use Edit->Copy to Clipping Window->Copy to XXX, where XXX is the name of your global clipping window.
From this point on, you can merely drag and drop that clipping onto any track.
Hope this helps.
Chuck
iMac (Retina 4K, 21.5-inch, 2017)|| 16GB Ram || OS/X 10.14.6 || Motu 828MkII || Steinberg UR242 || DP8.07
Macbook Pro (Retina, 13-inch), 2.7 GHz i5, 8GB Ram
Chuck
In the Track window, is there a way i can create a clip at the beginning of my MIDI track and add all my CCs ?
The only way i found was to go to the MIDI Edit Window, open a controller lane, pencil in your values for CC1-CC7 and CC11...quite tedious I guess i can also insert those CC events in the Event List. Is there a faster way ?
Using the technique I described, you'll only have to do the manual entry once. It's drag and drop after that.vudoo wrote:In the Track window, is there a way i can create a clip at the beginning of my MIDI track and add all my CCs ?
Chuck
Chuck
As i'm new to DP, i'm trying to find the best way to enter CC data since one cannot create clips.
Once the clip is created, i can use your method, option drag or copy paste to add more clips, but as i've mentioned it's the different methods for recording CC that i'm interested in. Thanks
- Primary DAW OS: Windows
You can also use the "Insert Continuous Data" command in the Region menu. Select the first measure of as many tracks as you like.
It's designed to insert a curve, but if you enter the same values in the "Change smoothly from ___ to ____", you'll get a single value at the start of your selection.
Repeat as desired for each CC.
DP 10 - Win 10 - Ultralite AVB
Ah this is great, saves lots of time...Do you know if there's a way to insert more than one CC ? Thxmesayre wrote:You can also use the "Insert Continuous Data" command in the Region menu. Select the first measure of as many tracks as you like.
I don't think so. If your template doesn't change much you could always include the CC's in your template.vudoo wrote:
