This feels like a "Sharing & Permissions" issue.
I recently had a problem with a 2 year old SSD that I was using as my workspace. I made sure everything was backed up, so there is no data loss issue here. It's been replace under warranty, but ever since, I cannot load a DP session that lives on that disk. DP starts, but the session won't load. No problem loading a session from another drive. Add to this that OSX (10.9.5) asks for authorization before copying to this disk, and it feels like a Sharing & Permissions issue (in the Get Info window).
Can someone tell me how the proper permissions should be set for a standard work disk?
What I see on a working disk:
ghobish (me) rw
staff rw
everyone r
What I see on the new drive:
system rw
wheel rw
everyone r
I tried added myself to the list with rw but that didn't help. I tried to add staff but couldn't find that option anywhere. Also tried increasing "everyone's" privileges to rw.
Do I need to take care of this with line commands in Terminal? I can also try erasing the disk and re-copying the data (it's all backed up) but thought I'd try this approach first.
OSX Mavericks 10.9.5 on a MacPro 5,1 w 24GB RAM
Thanks.
(oh, and if Mortilla's reading this- I did repair permissions, but this is not a system drive... )
DP Session won't run from specific disk
- ghobish
Gary Hobish
A. Hammer Mastering & Digital Media
San Francisco, Ca
http://ahammer.com/mastering
Mastering: Mac Studio M1 MAX 2TB SSD, 64GB RAM, 32-core GPU, OS 12.6; DP 11.22, Waves, Izotope RX10 Advanced, Alloy, Nectar, PSP stuff, Plug-In Alliance, Metric Halo ULN-8 MkIV, Euphonix MC Control & MC Mix, Presonus Central Station, and (still) no air conditioning (but at least now there is airflow)
Annex: Mac Pro 2010 5,1 3.33GHz 12-core, 80GB RAM, 10.14.6, DP 11.22, Metric Halo ULN8 MkIV, MOTU 2408III
San Francisco, Ca
Re: DP Session won't run from specific disk
Add yourself as admin.
Check the box to Apply to all folders and files...
- ghobish
mikehalloran wrote:Add yourself as admin.
Thanks Mike, but if you reread my post you'll see I tried that.
Gary Hobish
San Francisco, Ca
San Francisco, Ca
Really? You only listed the first part, not that you had checked the box to Apply...ghobish wrote:mikehalloran wrote:Add yourself as admin.
Change all to Read & Write. Check Apply to files and folders. You need to do this individually on each line.
- ghobish
mikehalloran wrote:ghobish wrote:mikehalloran wrote:Add yourself as admin.
Went back and did all that, no good. Ended up erasing the drive and the proper permissions came back. Re-copied the files, all is OK. Thanks.
Gary Hobish
San Francisco, Ca
San Francisco, Ca
