Needing a Loop Tutorial
- csiaudio
- Location: Indiana; Where the corn is tall and the women are wide!
I rarely use loops but Big Fish had some that I like on Black Friday so I picked them up. It came with Apple Loops, REX & WAV's but I'm doing something wrong because when I drag them in and adjust the tempo the loop doesn't change to the new tempo.
So, if anyone can direct me to a video tutorial I would appreciate it.
Thanks.
Thanks.
Capturing the Colors of Sound!
Mac Mini M1 2020 -- DP 11.2 -- Universal Audio Apollo Quad -- Apollo Twin -- SPL Kultube Compressor -- Slate Virtual Mic -- Eve SC207's w/KRK Sub
Re: Needing a Loop Tutorial
EDIT:
See post below for original quote. I stand corrected!
I will go and RTFM.
I will go and RTFM.
?? Have a look at p 33. in the V9 manual. Don't know the page in the V8stubbsonic wrote:I don't think DP will adjust those loops the way Garageband does.
For Acid and Apple Loops: tempo will be imported with the audio so that it will automatically conform to the sequence tempo when placed in a track, as long as automatic tempo conversion (as explained in “Automatic Conversions” on page 79) is enabled.
There is a similar instruction for REX files on the same page.
- csiaudio
Hey Bayswater - yeah this is the issue so I'm glad you brought this up. I have all the proper things checking the the Pref's "Background Processing" and still the imported file is not conforming. I did actually read the manual before posting and should have mentioned these things so again thanks for point this out. Any thoughts on what I'm doing wrong?bayswater wrote:?? Have a look at p 33. in the V9 manual. Don't know the page in the V8stubbsonic wrote:I don't think DP will adjust those loops the way Garageband does.
If you have Stylus RMX, you can convert them with Spectra's SAGE converter and use the loops in RMX.
Otherwise , I think there should be another preference in DP along w/ automatic tempo conversion-sorry not in front of my system now.
Sorry, no I don't. Haven't used loops for a very long time, and not with V9, but it seemed pretty simple when I did.csiaudio wrote: Any thoughts on what I'm doing wrong?
