Change pitch bend wheel controller # in real time?
Hi,
So my piano (Yamaha DGX-230) only has a pitch bend wheel. It sends pitch bend data obviously.
My Garritan sounds use the Mod Wheel (controller #1) to change the volume of many sounds on the fly.
The DGX does not appear to give a way to change the CC # which the pitch bend wheel sends.
So I'm wondering if DP 9 has a feature which, on the fly, "catches" the incoming pitch bend data and in real time can transpose it to another CC # -- like #1 for volume.
Any thoughts? Thanks!
--Prahas
--Prahas
Re: Change pitch bend wheel controller # in real time?
Hi. So I found the custom console. See attached.
The pitch bend wheel (with these settings) is now effecting the volume (yay) but it is still sending pitch bend data. (boo)
I want it to only send volume data.....
Ideas?
(Click url to see console settings)
https://musingsofadisciple.wordpress.co ... 2/01/temp/
Ideas?
Maybe one of the MIDI utilities, like MIDIPipe could be used to do the conversion before the MIDI messages get to DP.
MIDI effect insert>Reassign continuous data. You can then save presets for different controllers.
Thanks both of you.
My sense is DP is capable of it -- I don't think I need to go to a 3rd party util.
I can't find "MIDI effect insert"
"Reassign continuous data" is under "Region" menu -- as far as I can tell, it only works after the fact -- after you've recorded a track with controller data, you can re-assign it here.
I want to reassign in real time -- as I'm recording. And I want to make sure the original data -- pitch bend -- doesn't get thru.... only the reassignment (volume [7] or mod wheel [1]) does get thru...
Choose a MIDI track channel strip in the mixer, click on an insert, and you'll see the MIDI effects there to choose from.PDN777 wrote:
You are a genius! Works like a charm. Thanks.
