I don't know how to do that. Any hints? I'll do a little Google research in the interim...James Steele wrote:I wonder if there's a way to trick it into installing. A lot of times you can inspect the package contents and find executables inside that will run. They may have a good reason, but I'm always curious if you can simply create the directories and move the proper files where they belong and put the AU in the Components folder and get it to work that way.HCMarkus wrote:Sorta' bummed. This is the first VI I've wanted that has enforced 10.9 or higher. The installer won't run under 10.8. Just gonna' have to pass; I can't afford the risk/time to move to a more current OS right now. Not like I'm hurting for bass sounds, but MODO looks pretty cool.
Edit:
https://www.macobserver.com/tmo/article ... installing
OK. Assuming I am able to open the package, how will I know where the components go?
