Set Bit Gain info
supersonic
Set Bit Gain info
Post by supersonic »
Hi
I was wondering if there was an option to view the gain applied to each bite (much like in PT) so that one can see if and by how much it was changed. Right now the only way I see is to apply the bite gain I though I applied in the first place and see if the waveform changes. Quite cumbersome.
Music is movement in silence
davidh
Re: Set Bit Gain info
Post by davidh »
Select any soundbite in the TO or SE and then either choose "Sound File Information" from DP’s Studio Menu or right-click on the selected soundbite and choose the same option from there.
Near the bottom of the Sound File Information window which appears, is the bite gain for the selected soundbite.
You can also use the popup at the top of this Sound File Information window to select which soundbite you need the info for.
Mac Pro 'Nehalem' 2 x 2.66 Quad Core, 28GB, 10.11.6 || MacBook Pro 2.7 Intel Core i7 Retina, 16GB, 10.11.6 || MOTU 2408 Mk3, 828 Mk 2, MTP AV || DP 9.51 & 9.13, Mach 5 v3, MSI, Ethno2, MX4, VEPro6, all Spectrasonics, Kontakt ... and many of the other usual suspects.
http://www.thekeyboard.co.uk
