Squinting to See Chunk/Sequence Names
- ggm1960
I've wondered about this for a while, been using DP on live gigs since version 5. Using 9 now and I've always found myself squinting and having to stick my face in the screen to see which chunk/sequence I've loaded. I don't suppose there is a way to pop out, or increase just the size of, the chuck name?
Greg
Greg
MBP's, DP10, 828x's, MTP's
https://www.facebook.com/Meinfield-346702719450783/
- Dwetmaster
Re: Squinting to See Chunk/Sequence Names
I'm afraid there's none.
What I do is I always write the Chunk's name as a first Marker for every chunk. And I show the Marker name in my transport window,
Works fine for me.
Works fine for me.
I enabled Zoom in System Preferences > Accessibility > Zoom so I can zoom in by holding down the Ctrl key.
**Leigh
**Leigh
I don't care what you play. I care how you play.— Karl Berger
iMac Pro 3 GHz 10-Core Intel Xeon W, 128GB RAM, Mac OS X 14.2, DP 11.3
Name everything in all caps?
speaking of squinting... any way to make the bar numbers bigger in SE and Tracks window. I have good eyes but come on if its on a second monitor a 5 or an 8 is tough to tell the difference. There is a ton of room on the line. PIA... blind or not...
waxman
- Dwetmaster
Only problem with that is: When you're live on stage, zooming in and out while playing is not always an option...leigh wrote:I enabled Zoom in System Preferences > Accessibility > Zoom so I can zoom in by holding down the Ctrl key.
**Leigh
- buzzsmith
Just a quick thought. Haven't tried it.
Would reducing the display resolution make everything a bit bigger?
Buzzy
Buzzy
Yamaha C7 Conservatory Grand
Hammond B-3 / Leslie 145
Focal Twin6 Be(s)
Focal Twin6 Be(s)
I've been experimenting with this now that my older eyes complain. Best thing for me would be to upgrade my aged Mac Pro 3,1 and/ or graphics card so I can attain Retina like resolution with clear crisp, un-pixelated text and graphics but still haven't found a good solution.buzzsmith wrote:Just a quick thought. Haven't tried it.
Buzzy
Frank Ferrucci
http://www.ferruccimusic.com
- ggm1960
This seems like a good suggestion and I'm gonna for sure give it a try, thanks!Dwetmaster wrote:I'm afraid there's none.
Works fine for me.
- ggm1960
This could be a real good option for me also, the only time I want to see the chunk name is right after I load it. After we start the song I'm know what we're doing!leigh wrote:I enabled Zoom in System Preferences > Accessibility > Zoom so I can zoom in by holding down the Ctrl key.
**Leigh
I wish I always felt that way.ggm1960 wrote:After we start the song I'm know what we're doing!
- daniel.sneed
That's what I do, and then I set a huge counter window (screen length), set to display time and markers.Dwetmaster wrote:I'm afraid there's none.
What I do is I always write the Chunk's name as a first Marker for every chunk. And I show the Marker name in my transport window,Works fine for me.
I can read the markers from opposite side of stage!!!
dAn Shakin' all over!
I edited the theme so the background to the column headers is white. Not so attractive but it gives a bit more contrast than the grey on grey that most themes give you. Otherwise all you can do is go to a lower screen resolution.
Big font in lyrics window works for me
