Has anyone at MOTU said they would put in a global pre-gen bypass? Both 9.1.2 and 9.02 can live on the same machine if named differently. I have it ready just in case. Thankfully I'm not having issues but if I do I will use both. But 9.12 is completely solid for tracking and I'll never go back to tracking with anything else.amplidood wrote:having to select pre-gen status for every single damn plug-in individually is nonsense. A huge step backwards from the option we had previously. Even then, the previous pre-gen engine didn't have the crazy issues that exist now. Someone seriously screwed the pooch.
I've only mixed a couple songs since 9.12 was released with no dp issues but they were 30 count audio track songs with BFD3 being the only MIDI. If I was having the issues being identified here on m-nation I would just use both. It's probably because I'm not doing large template projects with lots of MIDI tracks. Seems the large template MIDI tracks are the kiss of death.
I admit I get paranoid from what I'm hearing. Since 9.1 I've started everything from an empty template. I have everything set up on batch command and quick keys. It's not as fast as opening a template but it's not slowing me down.
I am experiencing meters on plugs not being in real time when inserted on the audio track. I've started doing parallel FX with those plugs like Manley mu. I'm with Andrew Scheps on doing lots of parallel compression and FX. In aux channels the meters are fine.
I'll be glad when this version gets a few more revs cause it's kinda walking on eggshells. Most of you guys have gone back to 9.02. I've been dodging the bullet.
