Some plugs will do that. In particular noise reduction plugs have moved samples. Hasn't happened in many years. On my systems BTD is 100% reliable with the exception of certain Kontakt 3rd party instruments that are heavily scripted.bongo_x wrote:Did you zoom in and make sure they're aligned at the sample level?
Occasionally PT will bounce things just fine, but the file will be stamped 1 (or a few) samples off. I haven't seen that in DP, but what you're describing sounds like 2 files that are a sample off, you will only hear very high frequency content then as the lower stuff is still in phase enough to cancel out.
Bounce vs Real Time
Re: Bounce vs Real Time
ah, Buzz, I goota call "oops" on myself.buzzsmith wrote: ...Only thing I miss is the VU meter display to make sure that I'm not red-lining....
I was bouncing; a bunch of MIDI tracks - all going thru Kontakt 5 instances - and one audio track and I noticed that none of the DP MixBoard meters were moving, but all of the Kontakt 5 meters were...fwiw
Kurz Midiboard, MOTU MTP AV
https://vimeo.com/71580152
~me
~me
Another benefit to a RT print track is the ability to punch-in for fixes.
DP9.12 / OS 10.11.6 / VEPro6 / Pro Tools 12.5 /
MacBookPro 15" 2.7GHz/16GB RAM/27" Cinema Display –
MH LIO8 / UAD-2QUADx2 / UA Apollo Twin
You would punch in on a final pass? Brave!merrek wrote:Another benefit to a RT print track is the ability to punch-in for fixes.
I'm not that brave.merrek wrote:Another benefit to a RT print track is the ability to punch-in for fixes.
We do that with film transfers and it makes sense there.
